b2620 (2x20 series) greasing
   / b2620 (2x20 series) greasing #1
Charlton John
Gold Member
North East New York
Kubota B2620
Hi, I am hoping some of you 2x20 owners can help me. I am failry new to tractors and new to my 2620. In greasing the loader in the manual it shows you the 10 grease points but where do you actually apply the grease in these fittings? My older New Holland had a different set up. The manual dosent realy specify where to put the actual grease. Thanks!!
   / b2620 (2x20 series) greasing #2
There should be a zerk fitting at each lubrication point on the FEL (at least there is on mine) to attach a grease gun. You may have to raise or lower your FEL to be able to see some of the zerks.
   / b2620 (2x20 series) greasing #3
Make a copy of the book with the greese locations so you don't mess up your nice book...
If you can get an air powered greese gun. Just fun to use..
Have fun. Let us know how it went..........
RRBota, Thanks. Do you have to raise and lower your FEL to get to the zerks on yours? I was wondering this as all lubrication points didnt look the same. I didnt raise/lower the FEL as you suggested in my initial check.
   / b2620 (2x20 series) greasing #5
I could actually see all of the zerks on my FEL, but changing the brackets positioning a bit by either opening or closing the pivot points helped make it easier to get a grease gun nozzle on them.
Hoosier Daddy......great suggestion on using page copies to prevent getting the manual all filthy ! ! :D
Thanks All, Actually spending a little more time looking at the loader I found all zerks needed for greasing. Now I know I read this on a recent post but how do you know when you have entered enough grease into the zerk? Also for the 2x20 owners it says in the manual to grease the loader control lever but in looking at the setup I cant determine where to apply this grease I didnt see any zerk or anything? Any thoughts? Thanks !
71061 (A49346)
71061 (A49346)
Woods 7200 3 pt Finish Mower (A50514)
Woods 7200 3 pt...
2008 Dodge Ram 1500 (A50515)
2008 Dodge Ram...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
71064 (A49346)
71064 (A49346)
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
