Who wants to sell me Deere accessories?
   / Who wants to sell me Deere accessories?
I got my all my lights (front and rear kits) via Green South. They were quick, especially considering I'm on the other side of the country. The lights are a great help. I don't think I've seen it mentioned before, but on the 2320, you can have the headlights on and the auxillary lights off without modification or an additional switch. That was a nice surprise. With the main light switch, the first position is off, second position is flashers only, third position is all lights on - not flashing, fourth position is headlights and flashers - but not the auxillary lights. Perfect! No need to add another switch.
Deere - if you read this, the installation instructions need updating for the 23xx series. They currently only indicate installation on the 3xxx and 4xxx series - not that I would have followed them though :).
I'm curious mjncad - you could install 4th and 5th, but not 3rd scv? I would have thought you would have to go in order with 3rd first and 5th last. What tractor do you have?
Scott
   / Who wants to sell me Deere accessories? #22
Scott
Scott:
I have a 2001 4200. The third SCV kit uses the third spool of the SCV that powers the loader. The 4th & 5th SCV kit has it's own valve and requires the Power Beyond kit to function. I bought the PB and 4th & 5th kit from a dealer near our recently purchased properly. The salesman was a PITA and it took 6-weeks before he got it right. Since I was going to tear into the tractor, I said what the heck, add the third kit while I can still get it.
What I'm finding out is that PB and 3rd SCV tie into the loader SCV, so I'm installing the kits in parallel. I had to remove the control lever from the 3rd SCV kit's Quadrastat control assembly and install it on the 4th & 5th Quadrastat. That was easy; but apparently Deere didn't figure they would sell many of these kits as the fender cover didn't fit. It hit a couple of nylon bushings on the Quadrastat assembly. No big deal and my Dremel took care of it.
I'm hoping a 1-3/16" crowfoot wrench arrives tomorrow so I can get into the meat of the matter of installing these kits. I'll try and get a few pictures before all is buttoned up.
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
More info coming soon! (A56858)
More info coming...
Commercial truck Frame with Axle (A59230)
Commercial truck...
