Gravel Driveway (again)
/ Gravel Driveway (again) #1
mntnvew
Member
SW Montana
Belarus 825
Hi all,
I just got my first real tractor, Boris, a Belarus 825. I am going to rebuild my driveway and wanted to get everyone's input (I know it is a common topic, but wanted to get comments on my specific situation).
Basically I live in SW Montana and we get a LOT of wind. In the winter we will get a few inches/feet of snow, then it will get blown away in a day or so as it isn't too long after a snow storm that the everyday wind is back in action. (if the wind even subsides while the snow comes, sometimes it is ground blizzard conditions). So we can get some HUGE drifts.
With that said, the previous owner of this property had a taller driveway constructed when he built the house in 1992. He stated he had the driveway built up so much to ensure the wind would just blow the snow off of it, instead of it creating a drift on the north or south side.
As you can see by the photos I included, the driveway is pretty much shot.
Now that you have a little background, here are some of my general question areas:
1. I was going to get a 8' box blade, 8' rear/angle blade to tackle this project. Is that reasonable?
2. The ditch can get kind of steep on the one side, will the BB and RAB work for me? (I dont want to tip my tractor over obviously, do I need to worry about this if I were to tackle with the tractor wheel in the deepest part of the ditch?)
3. What "expert" oh-crap's can anyone pass along (you know the things only experienced tractoring folks have learned over time)?
4. The height of the driveway over the surrounding area is about 8-10 inches. Can I acheive this with a BB and/or RAB? Do I need some special hydraulic RAB to do this? (I contacted my local road builder and he wants 5k to rebuild this 2/10 of a mile stretch of driveway, he would use a full size grader to do this he said) I cant afford a 3-4k RAB with all the trimmings. Could I use hyrdaulic top and side links to accomplish this? I guess it is the offsetting capabilities that allude me. However I am not even sure if I need offsetting capabilities for this project.
Any general comments, notes, opinions, etc... that could help out a green horn just getting into tractoring are much appreciated!!!
Boris, is almost 10' tall, has loaded rear tires & FEL.
/ Gravel Driveway (again) #2
Boris is a big dude.
Looks like you should be able to do that project no sweat. You will most likely use the boxblade and angle blade for many other projects and future maintenance anyway. Size of implements sounds right to me. There should be a manual adjustment for the top link and side links too. That will allow you to cut or rip and tilt the blade(s) to one side for crowning the drive.
Just watch out going in that ditch along the side of your road and go slow. It doesn't look too bad, but you will feel it when you get the tractor tilted a little. Dragging a boxblade will help with tipping, but if you ever feel it tipping, stop and drop the bucket onto the ground quickly and back out with the bucket down. Raise the box a little but be prepared to drop it too if needed. If there is a wheel spacing wider than what you have now, make that change and put the wheels at their widest stance too. Once you get it fairly smooth with the crown you want, it should be a lot safer and easier. I would do your project myself rather than pay the guy with the grader. IMHO, your money is better invested in implements for future use and the tractor experience you gain is invaluable. That's what you got it for anyway, right?
My thoughts exactly. Why waste the 5k on a grader guy when I can spend that 5k on the following implements from tractor supply and be able to do almost anything on my property.
8 ft Hinged Back Box Blade $949.99 (2122214)
Loyal Harrow Drag 8X8 $399.99 (2128650)
8 ft Professional Rear Blade $529.99 (2137073)
SpeeCo Logsplitter 3 Point Complete $669.99 (2153304)
Post Hole Digger Standard Yellow $449.99 (2100220)
Auger Spiral 9 in Ring $129.99 (2100246)
The only one I cant afford right now is a back hoe, that is what I will have to save up for next summer :)
PS - Anyone know if I can get any discount from TSC since I am purchasing so many implements from them? I would really love a 10-15% off coupon :)
/ Gravel Driveway (again) #4
Congratulations on your (BIG!) new toy!
Sounds like you have a pretty good handle on what you need. I agree with rob that both the box blade and rear blade will have many, many uses beyond the driveway.
I'd recommend getting a rear blade with offset and tilt capability. This will allow you to work the sides of the driveway while keeping the tractor safely on the road. Between the adjustments on the blade and the side link on your tractor you can get some pretty aggresive angles that allow you to freshen up ditches as well, all from the safety of the driveway.
The adjustments can be manual or hydraulic depending on how much $$$ you want to spend. I have a manually adjusted blade and it works well for the 1 3/4 mile private road I maintain, though mine is only 6' and ~300 lbs as my 2210 is just a little smaller than Boris:D
With a tractor your size I'd get the heaviest blade you can find. I've never used this brand but they look well made and reasonably priced.
Beaver Valley Supply Company - Bison Rear Tractor Blades
I'll try and get you a picture of mine offset and angled if that'll help.
I saw those Bison blades this past weekend when surfing the web. The one I assume I would need is the:
BINVH-240 8' 3-pt Blade w/manual angle, offset and tilt, w/1/2 x 6" cutting edge 773 lbs. $1,585
It is about 650 more then i budgeted, but if I take into consideration that I can be safely planted on the driveway then I might be able to dump one of the other implements in my aforementioned list and go with the Bison. However, now that I think about it I would have to cover shipping too, that blade weighs in at 773 lbs, so shipping would be a pretty penny on top of the 1,585 blade cost.
Tough call really...
Anyone know of any cheaper offset/tilt rear blades I could consider?
Here is the list of implements I was going to purchase this weekend at the Tractor Supply in Billings, MT. (All the implement retailers around me charge astronomical mark up, for instance same implement at TSC can be 499.99, in Bozeman, it will be 799.99, just because it is being sold in Bozeman).
(all can be seen on tractorsupply.com, under agriculture and then 3 point (utility category)
Anyone have any thoughts on any of these products? Good/bad/ugly?
/ Gravel Driveway (again) #6
mntnvew,
I was typing when you made the last post whith the equipment list. The rear blade at TSC looks like it would do the job. It has offset and tilt. It does seem a little light for it's size though. Can't say from experience that it wouldn't hold up though.
/ Gravel Driveway (again) #7
Again, was typing when you posted. With shipping and your location I'd go with the TSC blade. If needed you could beef it up latter for far less than what it would cost to get one of the heavier ones "in the door". My blade is a J-bar that was pretty cheap, but they don't seem to make my model anymore and I don't think they have a lot of dealers. Got mine used in Louisville,KY but have no idea where it came from new. Sorry.
/ Gravel Driveway (again) #8
Nice tractor.
As to rebuilding the road I'd get a back blade and put gage wheels on it.
Suggestion on the grading work:
Use the back blade to windrow as much of the present road surface to one side of the road as possible. Roll this windrow back and forth till the road surface seems even and smooth but leave it on the edge of the road. Then work on the other side of the road at 90 degrees to the road and use the loader bucket to bring material from the ditch and side slopes to the road. Then windrow this material into the existing windrow and move the windrow back and forth a few times leaving it on the opposite side as be before. repeat the ditch dirt procedure on the other side. Now start windrowing back and forth to get an even distribution of materials and then use the gage wheels to leave a little on pass till you run out of material.
This should approximate what the road grader can do.:D
Happy road building.
/ Gravel Driveway (again) #9
Looking quickly at the size, price of the stuff you list, it looks to be all very light duty. I would fear it would twist up very quick. Unless your soil is very light loam with no rocks.
For comparison, my box blade is 66" wide and just shy of 1000 pounds. Your choice of 8' and 750 pounds would make it pretty light. Both fragile and not good at tearing into hard soils.
jb
/ Gravel Driveway (again) #11
Are you going to get a smaller companion for Boris and name her Natasha?
OK, I'm biased against 3PH post hole diggers based on the one I owned. If it were me, save the almost $600 on that lightweight PHD, and rent a hydraulic one to dig your post holes. A hydraulic one can be reversed if it gets stuck, while a PTO powered one can't. I had mine stuck all the way up to the gearbox in our claycrete dirt one time. I managed to wiggle it out in a similar manner that one rocks a stuck car in the snow out its jam.
Interesting approach, I was just trying to figure out where I could cut an implement or two lose due to dwindling funds...
I dont really have THAT much to fence... Thanks for the suggestion, I will give it a thought.
OK, I got a quick question, when I start to grade, should I start on the driveway side or the non-driveway side?
I was thinking that I would start on the non-driveway side and try to grade that to the ditch, then when I grade the driveway side, I can push all the material up onto the driveway.
All that material is needed so I can level out the driveway right?
Anyone have any thoughts? What about any folks that can provide links to diagrams of grading directions for a heightened driveway like mine (see pics in inital post).
Thanks in Advance!
/ Gravel Driveway (again) #14
My gravel driveway has 8 " of fly ash (residue from the coal burned from the local power plant) that cost $0. I had to pay to have it hauled out here. I don't know if that would fly anymore. It was done 30 years ago. It is probably illegal, but it makes a very stable base on pure beach sand soil.
I love your tractor, it looks like a real bursier.
/ Gravel Driveway (again) #15
Hi all,
My neighbour has a Belarus and his 3pt has downpressure so you might want to check a Belarus site with your model #
It will change any rear attachments ideas that you are looking at with regard to duty and strength if that beast has that feature
Good hunting
DGS
Good hunting
DGS
Boris has great down-pressure, with a old 3 pt snowthrower that dont work anymore, I was able to lift the rear of the tractor off the ground.
I have my implements on order, just waiting for them to arrive at the tractor supply in Billings :)
I have never wanted to build something so much (ok, since my last toy, horses, where as I had to build the high tensile fence, install gates, etc.)
I love toys :)
/ Gravel Driveway (again) #17
I would think that your choice of blades is really light. You need something like the Rhino 1540 to handle the horspower of your tractor. With anything much lighter than this, you will have trouble with it cutting into the soil AND standing up to your horsepower. It is rather expensive, but if you search used equipment, you should be able to find a good heavy duty back blade for around $2000. I think you could do this road job with just a back blade if money were a problem especially if you will be dragging the ditches to move the dirt to the road. With a heavy blade, with hydraulic tilt and swivel, you can do just about anything a grader will do. Takes a lot of practice to keep the rear blade from scalloping but you would have the same problem with a box blade untill you got the hang of it. If I was only going to buy one of the two for this project, I would use the larger rear mounted straight blade. THE Box blade would be good to use to scarify the existing road. Maybe even pull the gravel off and into a few piles that you could scoop up with your FEL and save to put back on your base when you finish with the build up. If you have a tooth bar on your FEL that should work just as well as the box blade scarifiers.
/ Gravel Driveway (again) #18
As far as getting the work done. I would turn the blade to about 45 horizontal, tilt it to 20 or so and swing it to the side so the end of the blade is at the edge of your rear tire. THen just drive your tractor directly down the center of the ditch and let the blade pull all the soil up to the road. Go up one side and down the other and you wont have to move the blade angles. Once you get all the ditches cleaned out and to the depth that you want, then start working the top as already mentioned with your blade. I would gather all the rock that you have and remove it to a spoil pile or piles though before I did anything else. THen just use the material that you can harvest from the ditches to build up your road. Set your tilt angle to what you want the ditch angle to be (20 degrees or less) and just keep running them and pulling the spoils to the roadbed. Once all the material is on top of the road, just keep working it with the blade moving it back and forth across the road and walking it in with your tractor to compact it. The gauge wheels would be helpful for this but it can be done without them.
GOOD LUCK. Just take it slow and easy with that light weight blade with that size tractor or you may end up with an 8" U blade rather than a straight blade.
