ATV Log Skidder
/ ATV Log Skidder #1
j.lwelding
Ottawa,Ontario,Canada
Kubota mx5100
Hello, I just wanted to get some feedback as to what the public may think of this idea for an ATV log skidder, I know that I have seen many models online but I wanted to build something with material I had laying around the house.I also wanted it to be different and as well did not want to add winch because of getting many many wire peices embedded in hands from past years of using winch cable even with gloves on.I thought that I would use the leverage system to do the work.I have used this many times to haul logs out of bush to get sawed into lumber and the sawyer doesn't want them dirty as they are hard on his blades,this unit works well to prevent this from happening.I know that the tires are narrow,I put them on just because I had them laying around and wanted to make sure concept was going to work, it does, so now im going to replace with atv tires.I have lifted many large, long logs so far works great.
/ ATV Log Skidder #2
can you repost the pictures as .jpg or .gif files (open them in paint and click saves as on Windows 2000 or greater)
Thanks
Aaron Z
/ ATV Log Skidder #3
It looks like it will work. Often the simplest things are the best. From what I see of your design, there's no need for a winch.
Great idea. Thanks for sharing.
/ ATV Log Skidder #4
so far it looks like it gonna work. the only thing that comes to mind is the how you gonna lock the bar bar after lifting the logs up ? :confused: i hope you had something rigged so it would automatically lock it self so if it didnt, it would come up and bang you in the arse or worse your head:eek: . could you elaborate on how you were planning to keeping the bar down ? may be a close pic in that area ? good work so far - smile.
/ ATV Log Skidder #5
looks like you better be careful how heavy a log you drag. might lift the back of your atv off the ground...
/ ATV Log Skidder #6
For what you're doing, it's likely fine. As Defective says, though, it might lift your ATV off the ground.
To transfer all the weight of the log that's lifted directly to the wheels, you might consider a more traditional logging arch design like one of these:
LogRite<SUP>?</SUP> Tools logging tools
/ ATV Log Skidder
The main beam that holds the log has a 3/4 inch hole drilled into middle of square tube and then it rests when in the down position between 2 pieces of 1/2"x4"flat bar with holes in each of them so that you put pin in to hold log arm in down position.
/ ATV Log Skidder
aczlan,Can you please provide me with your email address and I will send you the pics,Thanks.
/ ATV Log Skidder #9
just post them to the forum as an attatchment...
[rant]the problem with BMP files (and the reason I posted the request) is that they are 5-6x the size of .jpg or .gif files, in addition they do not open in a browser and have to be opened in paint. [/rant]
Aaron Z
/ ATV Log Skidder
here are the pics, hope they worked, new to this computer stuff so please be patient.lol Now I erased all pics and cant seem to add them again, unless I repost.
/ ATV Log Skidder
here are the delete pics i hope.
/ ATV Log Skidder #12
Ah-hah! (light bulb goes on). I now see the beauty of your creation. It was the one picture that I didn't see before...the hinged lever that raises the log.
I still think, though, that you might get better performance (ie. heavier logs and better maneuverability) if the weight of the log was centered between the wheels.
/ ATV Log Skidder #13
Ithink thats a nice lookin rig.Im building one this winter,i already have the axle and hubs and tires .Im gonna use a winch or comealong to lift them and then chain em up,and let the pressure off the winch.
ALAN
/ ATV Log Skidder #14
I haven't read all the posts, but I was wondering if you have the tongue-ball hitch where it will swivel 360 degrees as for sure it will tip over now and then if you pull from an angle. Nice looking creation though. I have been thinking of building something for my quad too.
/ ATV Log Skidder #16
These work real well.
Look at the yellow logging cone:
Manufacturer of the best Portable Winch with rope with capstan and a powerful Honda engine. Ideal for logging, rescue, construction, hunting, ATV, farming or boating Pulling Docks Portable Winch ATV Winch
We liked them so much along with the winch and pulley system we became a dealer. Their pulley/release system also would let you drive down a trail and yet still pull a log to the trail without having to get off and change pulley setups for each directional change. Wish I had thought of that idea!
They have lots of dealers you can buy them from.
Their choker chains and ropes as well as their pulleys are nice too.
Ken
/ ATV Log Skidder #17
[QUOTELook at the yellow logging cone:[/QUOTE]
Made my own logging cone. I took a 35 gallon poly barrel, cut it half, then cut a 4 inch hole in the bottom. Works great.
/ ATV Log Skidder #18
Now that is a great idea!!! I like it. Especially if you have the barrels with the curved sides. I have a few but they are too small
Ken
/ ATV Log Skidder #19
You folks motivated me to build one this weekend. I had enough stuff laying around so wasn't out anything but time. I made a bed that goes on the arch so it can be used as a trailer and dumped by the winch. My son came over a bit early so that part isn't on, but you can see how it works.
/ ATV Log Skidder #20
What about these? So simple, but the work really well!!!
Montana Jacks QuadSkidder w/Chain Kit - QS-2000
I'm really surprised that the mere simlicity of this set-up didn't see more attention with you guys. Why deal with tires and axles that are easily stuck or broken when you can slide right across the ground. This is the design I prefer as it it tough to break.
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
100 Gal L Fuel Tank (A65643)
100 Gal L Fuel...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
KUBOTA SVL97-2 (A65643)
KUBOTA SVL97-2...
2019 P.J. Trailer Trailer, VIN # 4P5F82029K1307542 (A65563)
2019 P.J. Trailer...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
