Snow Equipment Owning/Operating Snow surfing on a tractor
/ Snow surfing on a tractor #1
Botabill
Ontario
In one of the earlier threads one criticism of the Kubota BX (a small SCUT with 12 inch front wheels) was that it can't go through deep snow. I live in Ontario and in mid winter we can have 2-3 feet of snow on the ground and 4 and 5 foot drifts. I can pretty well travel through a foot of the white stuff in 4WD with turf tires even though I only have 8 inches of clearance. In deep winter though I can't travel around my field trails. Does anyone know what minimum size of tractor (model) can cruise through 2-3 feet of snow?
/ Snow surfing on a tractor #2
Unless you're looking at a full-size Ag tractor with beau-coup ground clearance, chains, and/or FWA, you will find it difficult to get very far "cruising" thru 2-3 ft without a lot of ballast, and all 4 tires chained-up, regardless of tire type.
Of course with a FEL you could take the time (a lot of it) to plow your way through the deep stuff.
/ Snow surfing on a tractor #5
Another question What good does it do to go with a bigger tractor than a BX when the larger tractor is still to low to the ground?
/ Snow surfing on a tractor #7
Man I think ya need a Snocat!!!!
I have a 2210 with a FEL and a span of 100 plus feet to the shop. The first good snow fall I plow to it and leave 5 inches of snow. Then drop the bucket and backout with the front slightly raised. Instant ice road over night. Use a blower the rest of the season.
Much cheaper than a new tractor.
Dan
/ Snow surfing on a tractor #8
A tricycle AG tractor does pretty well even tho only 2wd. The knife on wheels form and good ground clearance over nearly the whole undercarriage are a good combination. If only you could refit the front with a powered AG tread tire a tricycle would be nearly unstoppable.
larry
/ Snow surfing on a tractor #9
there are really only 2 ways to aproach "deep" snow.
1)have low enough ground pressure to ride ontop
2) have enough weight and hp to cut down through it and muscle through it.
so its either over or through
the little riding lawnmower aka SCUT fails both 1) to heavy not enough foot print 2) not enough power/traction
now put some madtrax on your SCUT and youve got a shot.
/ Snow surfing on a tractor #10
larry
I have to agree. We have an older International Farmall 560 with the tricycle front end. With standard wheel weights and no chains, it will easily go through snow 3' deep, all day long (as long as the ground underneath is solid). We also have a Farmall 656 with a wide front end, which should be more capable with additional horsepower and weight, but actually, it isn't nearly as good in the snow. I can't explain why that is, but it is the case.
/ Snow surfing on a tractor #11
None of the BXs have 12'' wheel that I know of.
They all have either 16 or 18 inch front wheels and 24 or 26 inch rear wheels.
I measured the front wheels. Right you are. From the floor to the top of the wheel 16 inches.
/ Snow surfing on a tractor #13
put a snow blower on the front and go where ya want to go.
/ Snow surfing on a tractor #14
It was relitivly common on older 2 wd farm tractors to run half tracks. A buldozer type track around the rear wheel then around a additional small wheel centered between the front and back wheels of the tractor. This was great for getting around in the snow. I have often wondered how a CUT fitted with them would perform.
/ Snow surfing on a tractor #15
I saw a 9N/2N/8N? set up like that in Wakefield, NH a few years back. Wish I took pics.
Adams 8 Ton Blender (A63118)
Adams 8 Ton...
(INOP) 2010 JCB 930 ROUGH TERRAIN FORKLIFT (A62129)
(INOP) 2010 JCB...
17601CFL (A59228)
17601CFL (A59228)
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
2020 Forest River Surveyor Camper, VIN # 4X4TSVZ21LL037533 (A61165)
2020 Forest River...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
