Kubota GR2100
   / Kubota GR2100 #1
george landis
Robertdale, AL 36567
Kubota B2710, Scott S2554, cub cadet 1525
Does anyone have a cure for the extremely rough ride on the 2006 Kubota GR2100. The seat, once you sit on it is metal to metal. There are no springs for the operator only a single, centered, weak spring for the seat switch. This spring will only hold the seat off the switch when no one is sitting on the seat. Also the front axle seems to have very limited travel/movement. My yard is not golf course smooth, but not very rough either. By the time I'm through mowing (approx. 2.5 acres) my back is sore and my kidneys hurt. I do not have this problem with a Scott S2554. I used my buddies 2006 Cub Cadet GT3100 w/54" deck and it rode like a dream. I might add that the Cub Cadet also left a better looking, smoother cut. However the Cub Cadet was not near as manueverable, leaving a whopping 72" uncut circle of grass. It also has a very limited lift on the deck making the transition from one area to another( yard to driveway) very hard on the deck and wheels. This is my first time, so pardon me if I'm in the wrong place or doing this wrong. Feel free to set me straight or contact me 251-945-1966.
George in Alabama
   / Kubota GR2100 #2
George you are in the right place and turn your knob " counter-clockwise" following the directional arrow at the front of the seat to soften up the ride. Check the air pressure in your tires too. Only put 18 psi in your rear tires. If these two things don't work for you look for other reason as to why you are having such a problem. My GR2110 rides good with a 54" deck. Your gas version should too.
   / Kubota GR2100 #3
OB1, the GR2100 is a Diesel. I believe it is pretty much the same tractor as the GR2110, except they improved the transmission (and possibly other things) on the GR2110.
jas67
   / Kubota GR2100 #4
For a nice ride I like about 10 lbs of air in the rear tires. I've run them as low as six but you will need to tube them.
   / Kubota GR2100
This is the third time I have written this reply. Logged in but will not post. Any suggestions on Kubota GR2100, diesel/54 inch. rough ride. Tried tire pressure in 2 lb increments. Only made it worse, more bounce. Problem is back and forth, not up and down. No seat springs, like in the G2160 and GR2110. Does anyone know if the GR2110 seat sub-assembly will fit the GR2100? I suspicion the front axle has extremely limited travel and that when it encounters irregularities it quickly strikes the frame thereby transmitting the force immediately and violently through the unsuspended seat. This causes a whipping motion side to side. Tempted to grind another half inch off frame to attempt to get more travel. Other riding mowers have one to to inches of clearance btween their cast iron axles and the frame. The GR2100 only has a half of an inch. Air seat?
Thanks
   / Kubota GR2100 #6
jas67
The G2100 is gas, they are the exact same tractor except the G2110 is diesel driven, the seats are the same. George take your tractor back to the Dealer before you modify anything on that front drive axle. The articulation rates on the glidesteer needs this tight clearance for the quick turning radius. Cutting or grinding the frame for clearance could make it unstable on a hill taking a shape turn. There has to be another reason for your discomfort on this seat. It must be defective. Surely your warranty will cover this.
   / Kubota GR2100 #7
OB1:
Kubota Tractor Corporation - Prior Tractor Models
According to this page on Kubota's site, the GR2000 is gas, the GR2100 is Diesel. The GR2010/GR2110 replaced these two. The GR2010 is gas, the GR2110 is Diesel.
   / Kubota GR2100 #8
You are absolutely right I stand corrected this was the first model run. I own a 2110 S/N 11263 P/N K1272-40001. This first series tractor the 2100 had severe transmission issues and possible seat recall like the BX series experienced. George needs to see his Dealer for help on this one IMHO.
   / Kubota GR2100 #9
George,
Did you ever modify your gr2100 seat? I also have a gr2100 and would like to make modifications to mine as well. You are right..............the ride is very "jarring" when mowing.
Does anyone have any suggestions?
   / Kubota GR2100 #10
George,
Get yourself one of those nice,cushy B series seats thru a dealer or ebay.They're made to accept the armrest kit too.Nice upgrade.I like mine on the GR2000.It's a direct bolt on fit.I also ran 1/2" angle iron back on each side and pinned the seat down solid to eliminate the sloppy rocking motion caused by the flimsy single front pivot/hinge.
2015 Nissan Altima Sedan (A48082)
2015 Nissan Altima...
2007 Trail-Eze TE80HT48DD 48ft 48 Ton T/A Lowboy Trailer (A48081)
2007 Trail-Eze...
2013 Chevrolet Impala Sedan (A48082)
2013 Chevrolet...
Coleman BT200X Mini Bike (A50860)
Coleman BT200X...
2017 Peterbilt 567 Tri-Axle Dump Truck (A48081)
2017 Peterbilt 567...
2020 RAM Promaster City Mini Van (A50860)
2020 RAM Promaster...
