Rear View Camera
/ Rear View Camera #1
themartaman
Stockbridge, Ga.
YM 2210
Wireless camera keeps my neck from getting stiff. No longer have to turn around. Guess you would call this customizing.
/ Rear View Camera #2
I'd be interested in brand and your installation.
Thanks
/ Rear View Camera #3
Me too. Installing one has entered my mind...... more than once. They have certainly gotten affordable enough for the average guy to buy. I'd like to see some pictures of your install.
/ Rear View Camera #6
I have one on my truck. You can't imagine how handy it is to hook up a trailer. You put the hitch right over the ball and you are done.
/ Rear View Camera #8
HELLO TO ALL,
i tried walmart, they had no idea what i
was talking about. then i tried radio shack,
they wanted $350.00 for one. i sure would
like to try one, i have lost so many things off
my implements, perhaps it would help.
good luck to all.
accordionman
wlbrown
/ Rear View Camera #9
Walmart's website Walmart.com: VR3 Wireless Backup Camera w/Monitor: Auto Says "not available in stores". Further checking on web for reviews of the VR3 gives pretty mixed conclusion. When it works, it's great, but it seems too often buyers had lots of troubles to get it hooked up and running. Surely wish we had a better 'picture' before ponying up a hundred bucks.
/ Rear View Camera #10
I am not sure why the website says that. I have seen them in walmart stores. I thought about buying one but the monitor is pretty small and I was not sure that it would be worth my time to get it. To the original poster. How well can you see what you are hooking up in the monitor that comes with that unit.
/ Rear View Camera #12
Google vr3 wireless backup camera and find several reviews and YouTube videos of this product. It apparently works well enough, but I'm thinking that a 2.5" screen in bright sunlight is going to be kind of sketchy. Might work best if you have a cab, or even a canopy.
/ Rear View Camera #13
I've got two Fleabay cameras, one of which looks identical to one on Amazon.com. My 10" monitor came from Fleabay too.
What I'm finding is that with the LCD monitor, glare is an issue. I spent an afternoon playing around with black foam core hoods to control glare to no avail. But if I hung a shield from the ROPS behind me, it negated the majority of the glare. OK, this is a good starting point to figure out something more permanent.
The other issue is glare on the cameras. The 120-degree wide angle has a built-in fold down shield that does little if anything to help. The 53-degree doesn't have a hood; but I cupped my hand around it to simulate a hood, and it helped quite a bit.
The other part of my glare problem is that I have the cameras mounted up high, and aimed downwards at a steep angle, which is getting reflection from the ground. I think once I move the cameras down lower (behind the seat), that should help a bit too. Also they will be under the canopy for some extra shade.
I'm also going to look and see if I can find some non-prescription photochromic plastic sheet (Transitions, Photogray) to make sunglasses for the cameras. I may also look into polarizing plastic sheets too.
Bottom line; when the lighting conditions are right, the cameras are a great help; but are worthless during the day if there is significant glare.
Picasa Web Albums - Matt - Lights, Camer...
/ Rear View Camera #14
try ebay they have day and night cameras that run off 12 volts they have the leds for some night vision.i think last time i checked they were about $35 make sure they say water proff not weather proff.but you still have to get a moniter.
/ Rear View Camera #15
Don't know about Pep Boys, but I've never had any problem returning something to WalMart so you could try it and return if it didn't do the job for you.
/ Rear View Camera #16
I did some research on it - VR3 doesn't exactly get glowing quality reviews - big rec is to get the 2 year warranty you'll need it people say.
I think its another case of you get what you pay for - the commercial systems seem to run around 600-800, and I'm guessing deliver. Thats basically what the option charge was for my truck backup camera as well.
I've decided to sit tight - I imagine like any other electronics they'll keep getting better and cheaper
/ Rear View Camera #17
MJNCAD:
What type of monitor are you using? I want to install one in my cab tractor. Since you now have two cameras how are you switching between them? Also, when you built your relay panel whose relays did you use, what model number?
I like the layout you did, nice neat job, well thought out.
Regards.
Glenn.
/ Rear View Camera #18
MJNCAD:
Regards.
Glenn.
Glenn:
The monitor I have is a bare bones (e.g. no speakers, no DVD player) 10" flip down monitor that has two video inputs. There is a switch on the monitor front to switch from video 1 to 2 and back again. It does have a dome light, which I hooked up; but that is the only bell & whistle of any significance. The monitor was made in China <GRRR>, so the brand name is a moot point. I suggest you go to eBay and start hunting for a monitor that looks like it will serve your purposes.
The monitor and cameras use so little current that I didn't see the need to run them through a relay.
As for relays, I got them at Del City Del City - Wiring Products and Professional Electrical Supplies. The relays I used are specialty relays. I used the prewired relay harnesses; but if I did it over again, I would have gotten the sockets with the terminals as there is less chance of having to splice a wire mid run. Relay Harnesses & Materials. The switch controlled side of the relay uses 18ga wire and the load side uses 14ga or heavier depending on application.
I hope this helps Glenn. If you add a monitor and camera(s) to your cab tractor, let us know how it works out.
Thanks for the compliments!
/ Rear View Camera #19
The problem I have found are that they have to have a lot of light to illuminate what your looking at
It would be absolutley usseless in winter snowblowing with snow sticking to window or the lens and also the monitor if on an open station machine
Glare in the bright sunlight is an issue also
DGS
/ Rear View Camera #20
Picture of the mounted camera?
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
2018 Ford F-150 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
2020 FREIGHTLINER CASCAIDA 123 6X4 T/A  SLEEPER TRUCK TRACTOR (A59908)
2020 FREIGHTLINER...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
