overrun clutch sticking
/ overrun clutch sticking #1
cadillac
Member
Sanford, NC
Kioti CK2510HST
When I first got the tractor (two weeks ago), the overrun clutch worked great. Yesterday though, when I push in the clutch it works for a second then starts pushing the tractor.
Is there any maintainance to be done to one, or anything to check?
/ overrun clutch sticking #2
Is the clutch internal to the tractor? or one of those aftermarket add-ons that slips over the PTO stub? If it's the latter, it just might be dirty. There's a spring return (or centrifugal) ratchet inside that could be jammed with debris.
//greg//
it is an add on deal. I'll look into removing it to see what I can see. It is used so who knows the state of things.
thanks for the reply
/ overrun clutch sticking #5
I had an overriding clutch one time on an 8n it worked fine then started not working. I looked at it and found a spring pin that held the inner workings in place had worked its way out to where it locked everything up. I took a punch and put it back in place and worked fine after that
I think the only normal maintenance is grease. Take it apart and see what's wrong. Worst case a new one isn't too expensive.
OVER RIDING CLUTCH - Agri Supply
wow, that seems too good to be true. Half price of other's I've seen.
1000 rpm max huh. Anyone know what the pto speeds are on a Mitsubishi D1600II?
My pto has four selections, but I have no idea what those equal in rpm.
/ overrun clutch sticking #9
I have a 4 speed PTO on my yanmar
1st gear should be 540 . Probably around 2200 - 2400 engine RPM
I bought the quick connect clutch( the yellow one in the pic.) for around $50.00
thank you for that info, guess I'll stop using 2nd. I had only used that for grass though...
