Mowing BX2350 mowing newbe
/ BX2350 mowing newbe #1
mac1968
I just recently purchased a bx2350 and mowed with for the first time this weekend. I know there has to be an operator error as it left marks in my yard. My yard is new, still has holes and bumps etc. But everywhere I made turns or on inclines it would leave marks. I like to mow my grass short . I set the scalp wheels low and mowed where the wheels where just above the grass. Any suggestions. Also is there a way to make the deck return back to the height you orignially had it. I know this is just some set up issues I have to work through. I mowed with my FEL still on, I don't know if that has anything to do with or not. One more thing I noticed was, that it beat me to death. I didn't know if once again if the FEL being on it effected that or not.
/ BX2350 mowing newbe #2
Welcome to the neigborhood.
I may not be able to answer all your questions since I have a BX 24, but I will try.
Mowing with the FEL. There is no reason why you can't leave it on, but my recommendation is to take it off. It does add some weight to the front and can cause it to bounce a little bit more. IMO, it just makes it easier to cut around things and not as easy to clip something important.
Rough ride, well not much you can do about that other than fill in the holes. The tractor should identify all of them for you.:D
Marks? What kind of marks, if you have other than turf tires, it is possible that when making tight turns it could tear up the ground, especially if you have to run 4WD. If you don't run 4WD, becareful of hills, it will/could take off on you and take you on a ride. Just make sure you have the mower level. The instructions in the book for the mower deck are pretty detailed.
Make the deck return? Return to where? There should be a knob that adjust the deck height.
/ BX2350 mowing newbe #3
First welcome to the forum and congratulations on your new BX. There are several things I notice when I switched from a garden tractor to a Sub Cut (BX2350). First additional weight will leave more pronounced tire marks. The marks you see on the turf are from the anti/scalp gauge wheels. The deck on the BX is a suspended deck and when I turn sharply on uneven ground the inside gauge wheel will dig in. My cure is to use a mowing pattern that limits sharp turns on slopes. Other that mowing (and setting gauge wheels) higher this is my only choice. I also mow at 3 3/4" to 4" in the heat of the summer and 3 1/2" in the spring and fall.
As for the rough ride, I feel your pain, No really I feel your pain, back and kidneys take a beating. I just had my 50 hr and my competent dealer reset my tire pressures to factory spec and I swear the seat belt was the only thing keeping me on the seat. 3 to 4 lbs lower tire pressure on the front and rear tires for a smoother ride. Note that I go back to the factory setting when using the FEL. Low front tire pressures WILL cause problems using the FEL. Adjusting tire pressures on the rear will also depend on whether they are filled or not. Also mowing with the FEL will not help the ride issues. It's so easy to remove and install it make no sense to mow with it. Make it a lot less like to do property damage also:D
/ BX2350 mowing newbe #4
I like to mow my grass short ..
That's your first mistake.
Most people mow to short.
I mow at 4'' and my yard looks better than the neighbors on each side who mow to short.
I like my green grass much better than their browned out burnt out looking lawns.
BTY:
My yard don't look all that much taller than theirs either.
megaboz, I am talking about the deck cutting into the yard, making marks (uneven) in the yard. I guess I should have said in the begining, when I went to pick up my tractor it was raining and the dealer didn't have much time to go over anything with me.
What I was referring to on height is if I start mowing and then have to raise the deck for some reason, is there a way to make it go back to the exact setting it was before without guessing.....
I guess this is where I don't understand, the dealer told me to lower my deck to where the deck wheels are just above touching the ground.
How do you set the mower to cut at 3.5 inches or 4 inches or whatever depth you would like. I don't want to sound stupid and really appreciate any help, I am wondering if in the rush to beat the rain and my tractor out if the dealer didn't give me all the owners manuals. I the little info he did give me I have seen anything on the mowing or deck control.
Thanks again, and this is my first tractor. I had a riding mower before this, so please be patient with me as I am new and learning.
/ BX2350 mowing newbe #6
When you are on your seat, between your legs should be an adjustment knob with number 1 through 4 and dots in between. This is your cut heght. I typically leave mine around 3 1/2 (like others have said). Most likely yours is at the TOP (should be on the knowb too.) At TOP the deck will drop as far as it can go. Also, it is posible since it is hydralic, that it could drop lower than what you positioned it at, that is why you set the height adjustment. Typically the only time the knob should be at the TOP is when you are removing the deck.
As far as the knob placement, that is where it is on my BX24, I think it is roughly the same on your tractor as well.
/ BX2350 mowing newbe #7
1*I set the scalp wheels low and mowed where the wheels where just above the grass.
2*Also is there a way to make the deck return back to the height you originally had it.
3*I know this is just some set up issues I have to work through.
4*I mowed with my FEL still on, I don't know if that has anything to do with or not.
5*One more thing I noticed was, that it beat me to death.
1*That's not how you do it.
Where did you have the cutting height knob set when you set the scalp wheels?
Here is how I set my Scalp wheels on my BX23 which is the same tractor as yours except I have the BACK HOE attachment.
Parked tractor on the level smooth concrete patio.
Raised the mower to it's highest lifted position, you must do this before you can turn cutting height knob in either direction.
Set the cutting height knob to its lowest setting.
Lowered the mower till it was stopped by the cutting height knob, not the scalp wheels.
Set the scalp wheels to where they were about 1/4 to 1/2 inch above the patio surface.
Raised the mower back up to it's highest lifted position.
Reset the cutting height knob to 4'' and all done.
2*That's what the cutting height knob does.
3*YUP
4*No it don't.
5*My BX23 rides very nice mowing even with the BH and FEL both installed on it at once.
You're probably going to fast is why yer gettin beat up.
L brown59:
PS I also have a BX1500 with a front blade and a rear tiller that rides fine with both of those implements on it at the same time.
My other BX1500 with a 48'' MMM rides real nice also.
/ BX2350 mowing newbe #8
megaboz, maybe the BX24 is different but on my BX1850 setting the deck height knob to "Top" keeps the deck all the way up so you can raise and lower the 3 point hitch without moving the deck.
mac1968, before you turn that knob you should raise the deck all the way up. That way the weight is on the 3PH rock shaft and not the knob. Then rotate the knob to whatever setting you want to mow at. When you drop the deck, it will stop at that height every time and you won't be guessing at the height. With the deck lowered to the height you want to mow at, adjust the gauge wheels so they stick down below the deck a 1/4" to 1/2" based on preference.
thanks guys....This info really helped. I will make the changes and test it this weekend.
/ BX2350 mowing newbe #10
did not read all the replys but i had the same problem
on a used bx2200 i bought this year. turned out to be the deck wasnt level
adjusted that and now can mow on 3 3.5 4 with out any problems no matter
how tight the turn is. everyone has a opinion on what height to mow at
do what you want your mower your yard. set the height you want then adjust
the scalping wheels accordingly.
/ BX2350 mowing newbe #12
It is possible that Since my knob doesn't line up with top, but more with 1, that maybe I am lowering it all the way down when I take the deck off. I started thinking about what you said, and you are probably right. I doubt that the two Kubotas are too different.
I end up learning something different everyday it seems like. I just learned not too long ago that there was an extra "float" feature on the FEL when pushed all the way to the right. I don't think float is the correct term for whatever that feature is, but it sure does lift the front of tractor up nice and high to drag that mower out from underneath.:D
Either way I think he got some of the information he was needing, or at least I hope he did. I
/ BX2350 mowing newbe #13
I've gotten a great finish cut out of my BX23 w/60" MMM going on 4 seasons now. I rank it as good or better than any of my previous dedicated lawn mowers and L&G mowers.
When setup right they perform very well.
The keys to a great finish cut are:
1) Have the MMM setup properly. Makes sure the front to back and side to side measurements are done at the blade tips and not on the frame of the MMM.
It's alittle bit of a pain to set them up as you've got to crawl around but once you get it right it generally stays that way. The owners manual is alittle hard to follow but is right on.
The side to side measurement should be within 1/32" and the front should be approx 1/4" lower than the rear. Surprisingly mower's perform better this way.
2)Proper anti-scalp wheel settings. actually, I'm breakng this rule some as I run mine a notch higher than what Kubota specs. At a notch higher they still provide their function of lifting the mower over bumps and rises ( preventing scalping) but they don't make "unecessary" contact with the turf in turns and straightaways. Since I mow at 3 1/2" the lawn looks pretty good and doesn't show all it's imperfections (which are plenty).
3) Proper air pressure. No matter what psi you run the tires, makes sure that the two fronts are exactly the same as well as the two backs.
I run mine approx 3 psi lower in the rears inorder to cushion the bouncing and this does pretty good. Course I had to compensate for this in the MMM setup but it wasn't too much of an adjustment.
4) Lighten the load. If you want the lawn to not show ruts and tires marks as bad then you need to lighten the tractor & mower up. In finish mowing, the lighter the better. Removing the FEL when finish mowing not only makes the tractor lighter by nearly 400 lbs but it also increases manuverability. That power steering and HST makes a BX VERY nimble when it's configured to give it's lightest and smallest footprint.
5) Good blades. Good sharp high lift blades defionitely out perform dull or bent or std lift blades.
In any case, there has been a few posts over the yrs where some have been dis-satisfied with the finish cut of their BX's but the vast majority of BX owners have posted great results with theirs.
Good luck
/ BX2350 mowing newbe #14
3) Proper air pressure. No matter what psi you run the tires, makes sure that the two fronts are exactly the same as well as the two backs.I run mine approx 3 psi lower in the rears inorder to cushion the bouncing and this does pretty good. Course I had to compensate for this in the MMM setup but it wasn't too much of an adjustment.
XYZ *power steering and HST makes a BX VERY nimble .
Good luck
xyz*How would you rate/campare that with all wheel steer?
/ BX2350 mowing newbe #15
Your deck adjustment knob may need adjusting. There is a trunion and nut on the top left side of the transmission when viewing it from the back. You can rotate the nut to adjust where Top is when you raise your deck all the way up. When I got my BX, I could not get the knob to rotate all the way to TOP, it would stop at 4+". Read on here or MTF about this adjustment. Sounds like yours is a bit too much the other way. Try playing with the adjustment knob so that when you have the deck all the way up, you can rotate it to TOP but no further.
/ BX2350 mowing newbe #16
Off hand I'd say that all wheel steer would definitely make it more manuverable but, I don't think that you could add all wheel steer to a BX size tractor. The weight lifting capacity alone of the 3ph would be too much for the mechanism to effectively support, at least affordably.....
/ BX2350 mowing newbe #17
When racing off-road motorcycles, I wear a kidney belt. It's sort of like a weight lifters belt that goes around your mid-section and keeps things from bouncing around too much. It might help you from feeling so beat up when the cutting is done. You can find them at any motorcycle shop that has dirtbike gear - $20.
'Frank
/ BX2350 mowing newbe #18
2*Mowing with the FEL. There is no reason why you can't leave it on, but my recommendation is to take it off. It does add some weight to the front and can cause it to bounce a little bit more. IMO, it just makes it easier to cut around things and not as easy to clip something important.
3* fill in the holes.
5*Marks? What kind of marks, if you have other than turf tires, it is possible that when making tight turns it could tear up the ground, especially if you have to run 4WD.
2*Leaving it on works fine for me
3*Fel is real handy for that.
Also a slower ride is a smoother ride.
5*My BX 23 has AGs .
I mow in 4wd with both the BH and Fel on it .
Tire markes are no problem.
/ BX2350 mowing newbe #19
1*The deck on the BX is a suspended deck and when I turn sharply on uneven ground the inside gauge wheel will dig in.
2* I also mow a t 3 3/4" to 4" in the heat of the summer and 3 1/2" in the spring and fall.
1*To stop that I set my knob to the 1'' setting and set the guage wheels 1/4 to1/2 inch above the surface.
Set the knob back to 4'' and keep it there for mowing the whole mowing season.
Took about 80 % of the mower rattling and banging away when going across the slag driveway too.
2*I mow at 4 inches high , have been mowing this 2.33 acres for 42 years now at that setting.
/ BX2350 mowing newbe #20
1*With the deck lowered to the height you want to mow at, adjust the gauge wheels so they stick down below the deck a 1/4" to 1/2".
1*If you adj the wheels with the knob set at that position you wil have to reset the wheels every time you want to mow at a different hight.
Also you don't set the wheels below the deck .
The wheels are supposed to be set above the surface/ground.
