Ford 1900 Wheel
/ Ford 1900 Wheel #1
HogSlayer6
MO/KS/AR
Case 930, Ford 1900 and 8N
Folks, I am in need of a left front wheel for my Ford 1900 tractor. I have welded the one I have several times with some success, but now it seems that none of my welds are holding up to the demands. I welded large thick washers over the existing holes but that won't last for long. Does anyone out there have a good one for sale or know of one for sale. I have searched the internet and everytime I get sent back to some off the wall parts advertizing page of one type of another.
Any help would be greatly appreciated.
Hog
/ Ford 1900 Wheel #2
Hog,
I don't have a wheel but you might specify it your 1900 is 4WD OR 2WD.
I'm sure a dealer would be able to get one but it would be $$$. I've been surprised that my dealer can get parts for my 1910.
/ Ford 1900 Wheel #4
Posting the tire size of the rim and the number of bolt holes along with any other information you might have on it might net you a rim from an unlikely source. A friend found a front rim for his tractor by looking at rear rims on compact tractors. Seems his front fwa rim was the same size as a rear rim on a compact tractor. Might also work in reverse....
David from jax
/ Ford 1900 Wheel #5
Tire / rim size? hub size? # of bolts, bolt pattern?
Here's alotta stuf chn lists.. what you got?
1900 3 CYL COMPACT T / 01A01 FRONT & REAR WHEELS
Key Qty Part Number Part Name Description
1 2 SBA336100550 RIM Wheel/Less Tire, 4WD, Tire Size Used 5 x 12, 1100, Start Year: 01/01/1979
1 2 SBA336100520 WHEEL ASSY Wheel/Less Tire, 4WD, Tire Size Used 6 x 14, 1300,1500, Start Year: 01/01/1979
1 2 SBA336100510 WHEEL ASSY Wheel/Less Tire., 4WD, Tire Size Used 6 x 16, 4.55" (115.6mm) I.D. Center Hole, 1700,1900, Start Year: 01/01/1979
1 2 SBA336100670 RIM Wheel/Less Tire., 4WD, Tire Size Used 6 x 12, 1200, Start Year: 01/01/1979
soundguy
/ Ford 1900 Wheel #7
Just get a proper welder working on the project the project.:D
yeah.. I agree... No reason the welds shouldn't hold if done right... I've done the weld a washer on trick on my rims with 100% good results.
have also welde dup holes and redrilled them, and welded in patched from one donor rim to another... neary a problem. All my welded or brazed rims are still running on tractors that I own..
soundguy
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2000 STERLING T/A DAY CAB ROAD TRACTOR (A64278)
2000 STERLING T/A...
2009 Volkswagon Jetta Sedan (A64557)
2009 Volkswagon...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A64557)
2006 Sea Ray...
Kubota L3901HST
Kubota L3901HST
36in AIM Bucket w/ Teeth Excavator Attachment (A64194)
36in AIM Bucket w/...
