Chainsaw bar length?
/ Chainsaw bar length? #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
How is bar length measured? The total length or the portion beyond the powerhead, i.e., the length that you can actually use?
/ Chainsaw bar length? #2
Good question. I just measured my two saws:
Husky 51 - 18" bar measures 16" useable length.
Stihl 310 - 20" bar measures 19" useable length.
Bar lengths taken from the stampings on the bar.
Harry K
/ Chainsaw bar length? #3
Pilot, this is one of those things I assumed I knew...until you asked.
I looked at Oregon's site FAQ Oregon® Frequently Asked Questions and you almost have it: tip of bar to fartherest cutter....rounded to the nearest inch. The rounded part threw me.
I would have answered from tip to adjuster holes in bar at mount end...and been wrong.
Turnkey, I have a Husky 51, great saw, love it, but usually only gets use on hunting/camping trips, a bit light for serious firewood cutting.
RavensRoost
/ Chainsaw bar length? #4
I looked at Oregon's site FAQ Oregonョ Frequently Asked Questions and you almost have it: tip of bar to fartherest cutter....rounded to the nearest inch. The rounded part threw me.
RavensRoost
Love mine too. I picked it up in a pawn shop about 5-6 years ago. I use it for my limbing and bucking small stuff. MS310 for the "big" saw (should have bought the 361 instead). Not a bad saw and will haul a 25" bar with skip tooth chain acceptably.
Harry K
/ Chainsaw bar length? #5
it may depend on the manufacturer. some may indicate bar length as what does it measure as a hunk of steel in your hand.
others may indicate from power head (or traction teeth) forward ie usable length.
generally i know my stihl bar length as a number of chain links as thats what really matters.
I stopped by the saw shop yesterday and the technician confirmed what schmism said: Bar length is defined differently by different manufacturers. So on my old Homelite, he measured it from between the hold down bolts or maybe some point between the bolts that I didn't notice.
I wish the industry would standardize this so I could compare specs from different manufacturers.
Thanks to all you folks who replied.
MF GC2300 fel replaced
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
SKID STEER AUGER ATTACHMENT (A62613)
SKID STEER AUGER...
Gehl RS5-19 (A62177)
