My 2320 Seat Fix
/ My 2320 Seat Fix #1
PCABE5
Wisconsin
John Deere 4066R Cab and loader
An update on my seat experiment, I purchased two seat suspension springs from JD (M153100 for and X series standard suspension) that were roughly the same base diameter as the rubber under the seat. I pulled the rubber and put in the springs and used a fender washer and small bolt at the bottom of each spring as a keeper and the ride is day and night. Rides like a it should have when new. I had cut the tops of the springs a bit to make it level when I am sitting on it. Overall took about 15 min and $12.64 to make a decent ride.
It is a cheap fix and cheap experiment. I mowed a bit today to try it out and my back it thanking me.
/ My 2320 Seat Fix
You could be waiting quite awhile:) .
/ My 2320 Seat Fix
Well, darn me. I will get some on here tomorrow.
/ My 2320 Seat Fix
Here is a picture of the springs installed.
/ My 2320 Seat Fix
Forgot to mention and it did not show in the photo but I glued thin rubber disks under the seat (where the old rubber springs rode) so the springs did not contact the metal of the seat. So far so good, no problems but a smoother ride.
/ My 2320 Seat Fix #8
Great idea - just ordered mine and will let you know how it works out. Thanks for posting
Brad
/ My 2320 Seat Fix
Thank you. I have about 8hrs seat time on this setup so far, no complaints and everything is working just fine. Let us know how your setup works for you.
/ My 2320 Seat Fix
So far everything is still going strong. I have put on another 16 hours and the wife likes the ride better as she has about 8 hours on it as well. It has been a cheap fix and better ride. I'm surprised nobody else has given it a try.
Now it is not a full suspension ride but it will give now with bumps and I have plenty on my property.
/ My 2320 Seat Fix #12
Hi - sounds great. Got my springs this weekend. Did you just do trials of cutting down the spring height or use some measurement to determine where the top of the spring should be?
Also, you said you used something under the seat to protect it from the spring - could you be more specific. I don't want to reinvent the wheel and you are so pleased with the ride if I can duplicate it I will be happy....
Thanks - appreciate your time
Brad
/ My 2320 Seat Fix
I installed the springs and sat on the seat to get a feel of the height and compression. Then to adjust the height I used a dremel to cut half a loop off at a time until it came out alright. Then I used a washer and small bolt to hold the spring in place (mine hasn't moved). Install, sit, take for a small ride then trim small at a time. Also if you do trim off some I ground the cut part flat so not rough edges, just like the spring came with the top loop ground flat at the end.
I used a rubber washer that I siliconed in place where the old rubber spings made contact. The washers were about 2" in diameter and I had them so I did not have to buy any. I only used them so there would not be any metal to metal contact. Heck if you like the ride cut a flat piece off your old rubber springs.
/ My 2320 Seat Fix #15
These should work on the 2520 too I assume?
If so, I'm ordering mine asap monday morning. :D
/ My 2320 Seat Fix
They should work the factory rubber springs are the same. I should have explained better before but I cut off half loops off the small part of the spring and not at the base until I got the ride I wanted.
/ My 2320 Seat Fix #17
I took that for granted!
Thanks for the info, parts will be here tomorrow. $5.90 each
/ My 2320 Seat Fix #18
Just did this, and it works great.
Love it, especially for $10!!!!!
Thanks for sharing this mod! :)
/ My 2320 Seat Fix #19
My question is; with the $$ JD wants for these tractors why didn't they do something like this at the factory? Boggles the mind.
/ My 2320 Seat Fix
Deadman,
I am glad you tried it and like it. It has worked great for me as well and the old butt and back appreciate it. For the money ($12) it is like getting a new seat.
Fork Extensions (A65640)
Fork Extensions...
Unverferth Lift Assist Wheels (A65640)
Unverferth Lift...
Bobcat 72SDR Seeder (A66285)
Bobcat 72SDR...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
2007 TRAILMOBILE 53X 102 T/A DRY VAN TRAILER (A59914)
2007 TRAILMOBILE...
2022 Polaris Ranger 1000 (A64127)
2022 Polaris...
