BX24 Throttle slips....fix?
   / BX24 Throttle slips....fix? #1
Jabroni
Central MA
Kubota BX24
The throttle is slipping on my new BX24. Is there an adjustment somewhere that I can tighten? It drops back, not the the other way around.
   / BX24 Throttle slips....fix? #2
It needs to be adjusted, call your dealer if it is new.
   / BX24 Throttle slips....fix? #3
On the previous models of the BX there was a couple nuts on the throttle lever pivot that you tightnened to keep that from happening. I haven't had the issue yet with my BX2350 and haven't looked at it, but I'd bet the same sort of arrangement is there. It's probably a real easy fix...
I'd call the dealer, but I think this is something that I should be able to perform myself and save the dealer call for something more extensive.
   / BX24 Throttle slips....fix? #5
Slipping is most likely due to a loose throttle link. Take off the Battery cover, You will see two nuts. Tighten the nuts. Problem solved.
   / BX24 Throttle slips....fix? #6
I had the same problem on mine ... As mentioned previously, about two minutes with a couple of adjustable wrenches will get you squared away. At first I was leery about doing it before I looked at it, but it is really simple and if you are like me, you will probably do it a couple of times (the first time I made it too tight, then too loose etc)
   / BX24 Throttle slips....fix? #7
So Jabroni, did you fix the throttle?? Mine (BX24) started doing it today...what a pain!! I got in after dark so I couldn't look at it.
   / BX24 Throttle slips....fix? #8
When my BX23 was new, my throttle was just the opposite, too tight. Two wrenches and about five minutes and it was perfect. It hasn't needed re-adjustment since.
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
PALLET OF NITROGEN APPLICATOR PARTS (A51244)
PALLET OF NITROGEN...
2010 Toyota Camry (A50324)
2010 Toyota Camry...
