BX24 Throttle slips....fix?
   / BX24 Throttle slips....fix? #1
Jabroni
Central MA
Kubota BX24
The throttle is slipping on my new BX24. Is there an adjustment somewhere that I can tighten? It drops back, not the the other way around.
   / BX24 Throttle slips....fix? #2
It needs to be adjusted, call your dealer if it is new.
   / BX24 Throttle slips....fix? #3
On the previous models of the BX there was a couple nuts on the throttle lever pivot that you tightnened to keep that from happening. I haven't had the issue yet with my BX2350 and haven't looked at it, but I'd bet the same sort of arrangement is there. It's probably a real easy fix...
I'd call the dealer, but I think this is something that I should be able to perform myself and save the dealer call for something more extensive.
   / BX24 Throttle slips....fix? #5
Slipping is most likely due to a loose throttle link. Take off the Battery cover, You will see two nuts. Tighten the nuts. Problem solved.
   / BX24 Throttle slips....fix? #6
I had the same problem on mine ... As mentioned previously, about two minutes with a couple of adjustable wrenches will get you squared away. At first I was leery about doing it before I looked at it, but it is really simple and if you are like me, you will probably do it a couple of times (the first time I made it too tight, then too loose etc)
   / BX24 Throttle slips....fix? #7
So Jabroni, did you fix the throttle?? Mine (BX24) started doing it today...what a pain!! I got in after dark so I couldn't look at it.
   / BX24 Throttle slips....fix? #8
When my BX23 was new, my throttle was just the opposite, too tight. Two wrenches and about five minutes and it was perfect. It hasn't needed re-adjustment since.
Horsch Joker RT32 Speed Disk (A50514)
Horsch Joker RT32...
2012 Freightliner Cascadia 113 Semi (A50514)
2012 Freightliner...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
2011 Ford Transit Connect (A47384)
2011 Ford Transit...
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
