L3400 toolbox
/ L3400 toolbox #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
One thing that the bare bones L3400 is missing is a toolbox. It got tiring not having a spot to put the odd clevis, pins etc.
I had planned on the dealer doing this when I sent it in for a 50 hr service but I ended up doing the service myself. I mustered up the courage to drill some holes in my tractor and I think I'm happy with the result.
This is a run of the mill metal toolbox I picked up at TSC, painted it Kubota orange. There didn't seem to be a perfect spot for it on this machine so this is what I settled on. It's bolted on well and I don't plan on carrying much weight in it but we'll see how my very first project holds up!
/ L3400 toolbox #2
Looks Good. I'll have to see if my 7610 can suport some mud flaps like that.
With my Backhoe I can't go behind the seat.
/ L3400 toolbox #3
Nice job Canoe. But I couldn't do that, I'm always in the woods and brush and I'd probably rip it off in no time :) I've got to ponder this a bit b/c I do definitely need a tool box on board.
j
/ L3400 toolbox
SR - no question in my mind. If I were to do it again I would put it behind the seat on the fender bracket that the SMV sign is and move the SMV sign. I ended up moving the SMV sign anyway.
/ L3400 toolbox
I should point out that with my wide R4's the box is not THAT exposed. I wouldn't want to go too close to a fenceline on that side though.
/ L3400 toolbox #6
In a Ace Hardware store I got expandable pipe plugs for the FEL tubes. They're easy to remove and install. The front tube being much longer is good for storing my 20 foot chain. I have this in addition to a tool box mounted behind the seat.
/ L3400 toolbox #7
Ya, I saw that chain storage idea in another thread and plan on doing the same. But a tool box back by the 3pth is KEY. Just gotta get time to do both since they're both pretty low on the to-do list. Getting things shaped up for spring is more important to the boss. I spent the entire w/end behind a power broom getting my drive way, back onto the drive way :) Power brooms are fun for about the first 20 min. Then they pretty much suck. My arms and shoulders are sore and my teeth still feel gritty from all the dust and dirt and rocks I was chewing on :)
j
/ L3400 toolbox #8
I have a L2800 and put my toolbox were the SMV emblem is located. Drilled two holes in the fender cross bar and installed the toolbox.I bought the toolbox from Sevens Tractor Supply in Coushatta Louisiana.The toolbox was $20.00 and is a replacement for a Ford 9N.:D
/ L3400 toolbox #9
I need a toolbox on my TC45......with my hoe, there just doesn't seem to be a good place:(
and a place for the chainsaw
and a place for the trimmer
and a place for .......
hahaha
/ L3400 toolbox #10
What are the expandable pipe plugs? Where would I go looking for them? What is their design purpose?
Usually used in plumbing, it's basically a rubber plug with a bolt through it and a wing nut. When you tighten the wing nut, it expands the rubber to seal the pipe. Kinda like a boats drain plug.
/ L3400 toolbox #11
they are great, the two under my cab area 3" worked perfectly but I used 4" on the fel crossbar. I had two put a little bit of electrical tape on them so they would fit nice and snug. The key to that is have it completely expanded out before you put the tape on or else it wont work. i have posted a pic of it.
/ L3400 toolbox #12
i am trying to post pic???
/ L3400 toolbox #13
In the trade (plumbing) they are called test plugs
/ L3400 toolbox #15
i was just at my dealer and saw they have a "tool box and Cup Holder" for use when a Backhoe is installed. it clamps onto the ROPS. Not a very big box, but better than nothing
/ L3400 toolbox #17
My L3700 has a tool box. Didn't realize that the L3400 did not have one.
/ L3400 toolbox #18
I'm a day late and a dollar short on this one, but my L3400 has a tool box too. I just bought mine last Friday, so maybe Kubota added it due to customer's complaints. Of course, it isn't big enough, so I may look for a place to put another one. Great thread! Thanks.
/ L3400 toolbox #19
Mine has one too (2010 model) it is not really large, but it is big enough for me. I am never really far from the house anyway.
James K0UA
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
2007 Mack CTP713 Wet Kit T/A Day Cab Truck Tractor (A64194)
2007 Mack CTP713...
2005 Chevrolet Silverado 2500HD Duramax Diesel (A66408)
2005 Chevrolet...
New/Unused Wolverine Hydraulic Screening Bucket (A65583)
New/Unused...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
9008SFL (A64556)
9008SFL (A64556)
