Kubota M9540HD12-1 4.30 star(s) (4)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Kubota M9540HD12-1.
50-100 HP Tractors
About the Kubota M9540HD12-1
Kubota M9540HD12-1 Discussions (84)
Here are the most recent M9540HD12-1 topics from our community.
  1. T
    M9540 cab disassembly question
    My pto spring broke and I’m pretty sure the only way to access it is to remove the entire ride side console that covers everything. Is there an easier way ? Is it as big of a PITA as it looks...
  2. T
    M9540 loader question
    Recently picked up a 2010 Everyting runs good but had a question on the loader, is it normal to have to rev the rpms up in order to lift the bucket up ? It operates as Normal except seems I...
  3. N
    Tires M9540 + R14 Questions
    2007 M9540 with rear cast centers, standard fronts per the following: 420 / 85 R 34 Rear Rubber 320 / 85 R 24 Front Rubber Has anyone else swapped to R14's on existing Wheels on the 9540? Does...
  4. L
    Kubota M9540 brakes
    Saw a message somewhere about Kubota brakes lasting the life of the tractor. I have an M9540 can tractor. Almost all work done is about hay. I had a little mishap. Rolled it over on its side...
  5. F
    M9540 with M35 loader, hose information
    My M35 loader rubbed a hole in the hose on the upper right hydraulic cylinder for the bucket curl. Can’t get a custom hose made because one end of the hose is proprietary (uses a red plastic...
  6. R
    Overheating M9540
    Hi, A friend recently bought a M9540 with a front 3 point linkage to run a mulcher. He's new to tractors and he was complaining about it overheating, then he proceeded to tell me it is running...
  7. A
    M9540 loader problem
    I have an M 9540 Kabota bought it secondhand loader off of a fairly new tractor installed it on my tractor and having problems with the Curl. Plumbed it according to the diagram in the parts book...
  8. J
    M9540 clutch question?
    The clutch pedal on my tractor was getting tight and was engaging near the top of the travel. Today I made an adjustment to the free play. The tractor operates much better with the clutch engaging...
  9. L
    m9540 Kubota
    Need to flush cooling system on my m9540. Want to flush block and radiator. Am not sure where to drain the block. Both radiator hoses attach to the block too high to assist in draining the block...
  10. J
    M9540 ROPS 4wd switch location?
    Any M9540 owners out there that might know the location of the 4wd switch that illuminates the indicator on the dash? I have the WSM and it shows the switch and how to troubleshoot it but not the...
  11. AGHardin
    M9540 Kubota
    Hey guys, looking into a Kubota M9540 cabbed tractor, 4wd, loader, Hydraulic Shuttle.. Has the ultra grand cab with air ride? seat. The tractor is around an 08 or 09 model. Been very well cared...
  12. M
    Mowing M9540 Pto vibrates
    I hooked my 6’ brush hog up to my M9540 and it basically shakes and vibrates my tractor so bad it feels like the windows are going to rattle out. If I hook the same mower up to my M6800 it mows...
  13. T
    NH TL100 or Kubota M9540
    Both with cab, and FEL. It appears by looking at tractordata.com that the TL100 drastically outweighs the M9540 by a few thousand pounds. Use of the tractors will be on our ranch, bush hogging...
  14. T
    M9540 Tippy / Light in the Rear?
    Looking at an M9540 cab tractor with loader. I have heard these tractors are pretty tippy when doing loader work. We do a lot if grapple work with FEL and move , load/unload a lot of round bales...
  15. A
    Hydraulic Top Link M9540
    Anyone install a HTL on the M9540? If so what size did you install? Have a 1 inch pin Cat 2 Reposting because some how I first posted this in the New holland section Looks like Fit Rite has a...
  16. A
  17. A
    M9540 gear ratio
    Anyone know what the gear ratio is for the M9540DHC24 SN 86399 ? The tire sizing is not matching up so trying to verify other possible issues. Have read the M7040 has a 1.438 ratio, but if I use...
  18. A
    M9540
    Been looking over some M9540's the last few days and came across something that brings up a question. All these are cab tractors and when I moved the POT lever to engage it lit up, but I started...
  19. S
    M9540 pto clutch pack
    Need some advise on how to put in a pto clutch pack for m9540
  20. S
    M9540/9960 PTO Brake Problems
    I own a 2015 M9960. Today, I was at my local Kubota dealer investigating bat wing mower options. While there, I noticed a split M9540 in the shop. As it turns out, the 9540 had been split to...
[ad placeholder]
User Reviews (4)
Read what TractorByNet members think about the Kubota M9540HD12-1 Subcompact Tractor
5
50 %
4
25 %
3
25 %
2
0 %
1
0 %
3.00 star(s)
Andytx
M9540HD12-1 Kubota
M9540 HDC 12
Model Year: 2006
The cab roof cracked in first month, took 6 months to get it fixed. The stereo went out after 2 years. In first year, the rear windshield washer broke and elwald. Kubota sent someone out twice to fix it. The front over head light had to be replace in first month due to water in them. The rear rim was bent when tractor when it arrived. Again elwald Kubota in Seguin, TX said to take a hammer and beat it out. That rim is still bent. After 3 years, front tires started loosing air turns out the cleats on outer rim that bolt to inner rim were cracking away from outer rim. The new tractors are welded around cleat of outer rim. I had to weld my own. Another thing fuel tank started leaking around drain on bottom since it is a plastic tank I had to find a glue that would stick and sealed up drain. Tractor has 12 speeds and actually need a creep speed added but that cost too much. The throttle is in wrong place when turning around in seat to look at plowing in rear I hit it with my knee and tractor throttles down in rpm. Actually no not happy with tractor but I am stuck with it.
Pros: Almost paid off.
Cons: See above review text.
4.00 star(s)
mattriggs
M9540HD12-1 Kubota
9540
Model Year: 2012
Bought from Normangee tractor in Texas. Tractor is solid. Had a few minor issues. Dealer did respond and apply fixes but with some delay. Having problems with lift and/or joystick controller. All in all a good machine.
Pros: Price.
Cons: Light weight.
5.00 star(s)
jenkinsmmarcusj
M9540HD12-1 Kubota
Stood the Test to Date
Model Year: 2008
This machine plows, (moldboard), disc, bales hay,(4x6), loads and unloads hay. feeds rolls to cattle and also drives hammermill. Pulls gravity wagons to crib and loads out manure. As it also has a bucket with quick attach it has also done some landscaping. Has 12sp trans and shuttle with 95hp and all the muscle I need. Would vouche for it's preformance against others of it's class. May not be green or red as our past tractors have been (still have some red), but as I work to live so shall my equipment.
Pros: Fits in many different places on farm.
Cons: Didn't get with cab. Must shift to lower gear1,2,3 for reverse.
5.00 star(s)
Anonymous Poster
M9540HD12-1 Kubota
Strong Utility Tractor
Model Year: 2012
Purchased open station model with LA1353S Loader with 3rd function capability and 84" bucket, two rear remotes, cast iron rear wheels and radial tires 12.4x24 front and 18.4x30 rear R1 AG, loaded rears. Very capable tractor, much more stable than I expected, never need additional rear ballast when doing loader tasks. Most of my work is in steep timber where this tractor rarely surprises me with unpredictable movement or shifting of weight. Controls are handy, work station is roomy and comfortable. Transmission shifter is sometimes tricky but expected with a cable shifter. Horsepower is never an issue and 12 speeds make correct gear selection easy. Hydraulic shuttle works very smooth and synchronized 6 speed makes gear changes smoothly. 3pt works precisely in position mode or draft mode. Lift capacity matches or exceeds machine weight. Extendable arms and telescoping links make equipment hookup and unhook simple. Three lift positions on arms and floating setting on lift links make 3pt compatible with any task. Overall very pleased with tractor and glad I went for 9540 over 8540 for added HP and larger tires.
Pros: Great HP/WT ratio, very nimble, user friendly work station.
Cons: Slightly tricky main transmission shifter.
[ad placeholder]
Kubota M9540HD12-1 Owner Pages
View owner pages to see photos, customization and comments about member-owner Kubota M9540HD12-1s
Kubota M9540HD12-1 Community Rankings
#183 user rating of 1508 50-100 HP Tractors items
#1036 Viewed of 1508 50-100 HP Tractors items
#16 discussed of 1508 50-100 HP Tractors items
#1244 user rating of 19625 items overall
#6677 Viewed of 19625 items overall
#171 discussed of 19625 items overall
