John Deere 5520_3 4.50 star(s) (2)
Information, reviews, photos, discussion topics, owner pages, and specifications about the John Deere 5520_3.
50-100 HP Tractors
About the John Deere 5520_3
John Deere 5520_3 Discussions (35)
Here are the most recent 5520_3 topics from our community.
  1. G
    John Deere 5520 Instrument Cluster Not Working
    I purchased a 5520, the instrument cluster is not working. I sent it to be tested and it works fine. I've had a mechanic work on it extensively with no success. The cluster has rpm, fuel gauge and...
  2. F
    Removing JD 5520 steering cylinder
    Need to replace the seals. Stupid question: do I need to jack up the tractor? I need to remove both tie rods.
  3. F
    JD 5520 "Clutch Groan"
    For the last few years had a noise coming from rear of JD 5520 when releasing clutch (clutch pedal up.) It is a groaning noise that stops once the tractor comes up to speed. Any gear, doesn't...
  4. T
    JD 5520 oil capacity
    Hi, just purchased a John Deere 5520 power reverser. Changed the oil and filter. I put in the 2.2 gallons of oil the specs called for but it’s not even hitting the tip of the dipstick. The 2.2...
  5. G
    John Deere 5520 Hydraulic Problem
    I have a 2003 John Deere 5520 cab tractor with less than 500 hours that I use a bucket and also forks on, but mostly forks. The tractor has recently developed an issue that is especially...
  6. J
    Light problems on John Deere 5520
    Turn signals and warning lights not working on John Deere 5520. Headlights working well lights not blown, and fuses appear fine ( although diagram in service manual does not match mine). Any thoughts?
  7. F
    john deere 5520
    hydraulic arms, lift but surge , you can hear the oil release . the traitor also surge to with the hydraulis
  8. R
    John deere 5520 pto
    The pto has gotten weaker over time, seems like the clutches may need replacing.. is it a tough job? Just looking for suggestions
  9. P
    JD 5520 No start
    Have a JD 5520 with about 250 hours on it and it suddenly won't start. I found the sticky on here and have done everything listed. Every time I turn the key on, the 20 amp fuse for the fuel shut...
  10. J
    John Deere 5520 Will Not Crank / Turn Over
    Hello, I am here hoping someone can help me repair my neighbors tractor. All of my equipment is old so the new stuff is a bit challenging for me. The problem we are having is that the tractor...
  11. M
    John Deere 5520
    Has anybody on here had any experience with a 5520? I have been looking at them on tractorhouse .com?
  12. R
    JD 5520 PowrReverser Slow in Forward, abrupt in Reverse
    We just replaced a fwd/neut/rev cable that was damaged on a JD 5520 with powrreverser transmission. The customer complaint before it came in for repair: Forward motion is delayed when using...
  13. L
    John Deere 5520 Clutch Problems
    I have a 2003 John Deere 5520. I bought it used in 2005 with less than 800 hours and the clutch went out. I took it to the John Deere dealer in Harrisonville, Mo and the Service Manager told me...
  14. S
    Added a skid steer adaptor to my JD 5520 and JD 790 QA loaders
    My Deere 5520 with a QA loader is great but I couldn't use skid steer attachments with it without an adaptor. I thought about it for a few years and finally bought an adaptor. I didn't want to...
  15. M
    John Deere 5520 hour meter
    I just serviced my JD 5520, looked to put the hours down and discovered that my hour meter no longer is working. I checked for loose wires and all fuses are good. Has anyone else had this problem...
  16. V
    John Deere 5520: No fuel coming out of injection pump
    john deere 5520 no fuel coming out of injection pump fuel getting to pump ok i disconnected one line at a time from back of injection pump no fuel. disconnected fuel line from injectors one line...
  17. S
    JD 5520 brake loss after hard use. Any ideas?
    My 5520 brake pedal goes to the floor after the tractor really gets used hard and is good and hot. After it cools down a bit, the brakes are back. It happened twice. Once on a 20 mile road trip...
  18. A
    compare jd 5520 vs koiti dk 65
    guys, what tractor do you compare to the john deere 5320 with cab @ air fwd. about 55 hp. I might like about 70 hp. with cab. and fwd. thanks much amberg
  19. DavidBR
    John Deere 5520 Advice
    Hey all, I have found a john deere 5520 MFWD Cab, Loader, triple rear valves, good tires, with about 1,100 hours on it. I think I can get it for around 34,000. Does this sound like a decent deal...
  20. bsrfarms97
    John Deere 5520 stuck in 1st gear.
    Hey everyone, I was looking for some input. My neighbor has a John Deere 5520 and its stuck in 1st gear.
[ad placeholder]
User Reviews (2)
Read what TractorByNet members think about the John Deere 5520_3 Subcompact Tractor
5
50 %
4
50 %
3
0 %
2
0 %
1
0 %
4.00 star(s)
nightshadow
5520_3 John Deere
5520 John Deere
Model Year: 0
As a whole, the tractor is good. It is not built to be stored outside. Fuel lines had to be replaced. Seat rusted out. Rubber parts are deteriorating. Has very good power. I bought a 541 loader with it. No trouble from the loader.
Pros: Power, hydraulics.
Cons: Not built for outdoor storage.
5.00 star(s)
Anonymous Poster
5520_3 John Deere
First John Deere
Model Year: 2007
5520 with a 541 Bucket and a three point back blade. Here in the mountains 4wd is the only way to go. I see so many guys trying to scrape up hill without the weight of the 4wd drive and they just bounce. By turning the Deere around and reversing the blade direction, it will grade going backwards all day long.
Pros: Great power. Easy to mount attachments.
Cons: Cost. Beanie weanies for a year.
Photo Uploads:
[ad placeholder]
John Deere 5520_3 Owner Pages
View owner pages to see photos, customization and comments about member-owner John Deere 5520_3s
John Deere 5520_3 Community Rankings
#146 user rating of 1508 50-100 HP Tractors items
#82 Viewed of 1508 50-100 HP Tractors items
#45 discussed of 1508 50-100 HP Tractors items
#998 user rating of 19625 items overall
#635 Viewed of 19625 items overall
#393 discussed of 19625 items overall
Highest Rated in This Category
    No results found.
