ZTM Flex Forks
/ ZTM Flex Forks #1
Buggs67
Perry Cty, Pennsylvania
Kioti 2014 CK2510 TLB
When I bought my Hustler ZTM they offered Flex Forks as an option for $300. As I was pushing the budget already and they didn't seem like they'd do much I declined. I thought it interesting that they'd replace the forks the mower shipped with and I'd get no credit for the forks.
Anyhow I'm looking for feedback from people who have Flex Forks. I put a suspension seat mount on and it improves the ride and comfort.
/ ZTM Flex Forks #2
Interesting. I watched their video. I could see where it could have some shock absorbing qualities. They show it flex, the deck dip down in the front and it somehow improves QOC. I'm a bit skeptical. Show your seat set up or at least what you bought. That seems like a good way to go.
/ ZTM Flex Forks #3
I have had a hustler fastrak for over 10 years and put the flex forks on 2 years ago, should’ve done it when I bought the mower. It does cut grass shorter if it is rough enough for the forks to flex but the smoother ride is worth it.
/ ZTM Flex Forks #4
I foam filled the front tires on my ZT which I don’t regret doing because I was getting constant flats. But the ride was noticeably worse. So based on a small change making quite a bit of difference I’d say they’d probably help.
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A64556)
2013 Freightliner...
2019 JOHN DEERE 325G SKID STEER (A65053)
2019 JOHN DEERE...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
