ZL-20 FEL Valve Comparison
   / ZL-20 FEL Valve Comparison #11
That's the "block style" valve, same as I have on my loader. A complete POS in my opinion, and soon to be replaced. Either with Ronald's or Tommy's conversion kit or a DIY job using a Brand valve, but that crappy thing has to go.
   / ZL-20 FEL Valve Comparison #13
Rob, here are the pictures of the valve on my ZL-20 FEL. Richard
That was the same valve that came on mine. I upgraded back in 2004 to a Prince Valve.
Chris
   / ZL-20 FEL Valve Comparison #14
Get a kit. I did mine myself before the guys came up with the retrofit kits and it cost as much if not more to get the valve, make a bracket, and then get custom hoses. Plus it took time and was a pain in the ***.
Chris
Richard,
I guess you got the consensus from the group to change out that valve.
I sent you the link to Ronald's aftermarket valve kit which I put on Loretta's tractor. It is sweeet and super easy to install.
   / ZL-20 FEL Valve Comparison #16
Rob, Your guess is right. I'ed like to run this valve for a time before I bite that bullet. Richard
   / ZL-20 FEL Valve Comparison #17
On the six hose block valve which is the pressure in line? Click to enlarge.
   / ZL-20 FEL Valve Comparison #18
Hope the picture comes through / works ??
Ronald
Ranch Hand Supply
   / ZL-20 FEL Valve Comparison #19
Ronald, Thankyou! Richard
Rich, Took me a while to figure out what pos ment.
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
2008 FORD F-650 (A50854)
2008 FORD F-650...
Pallet Fees (A50775)
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
