ZL-20 FEL Valve Comparison
   / ZL-20 FEL Valve Comparison #11
That's the "block style" valve, same as I have on my loader. A complete POS in my opinion, and soon to be replaced. Either with Ronald's or Tommy's conversion kit or a DIY job using a Brand valve, but that crappy thing has to go.
   / ZL-20 FEL Valve Comparison #13
Rob, here are the pictures of the valve on my ZL-20 FEL. Richard
That was the same valve that came on mine. I upgraded back in 2004 to a Prince Valve.
Chris
   / ZL-20 FEL Valve Comparison #14
Get a kit. I did mine myself before the guys came up with the retrofit kits and it cost as much if not more to get the valve, make a bracket, and then get custom hoses. Plus it took time and was a pain in the ***.
Chris
Richard,
I guess you got the consensus from the group to change out that valve.
I sent you the link to Ronald's aftermarket valve kit which I put on Loretta's tractor. It is sweeet and super easy to install.
   / ZL-20 FEL Valve Comparison #16
Rob, Your guess is right. I'ed like to run this valve for a time before I bite that bullet. Richard
   / ZL-20 FEL Valve Comparison #17
On the six hose block valve which is the pressure in line? Click to enlarge.
   / ZL-20 FEL Valve Comparison #18
Hope the picture comes through / works ??
Ronald
Ranch Hand Supply
   / ZL-20 FEL Valve Comparison #19
Ronald, Thankyou! Richard
Rich, Took me a while to figure out what pos ment.
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
JOHN DEERE 8410T TRACTOR (A51243)
JOHN DEERE 8410T...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
