ZL-20 FEL Valve Comparison
   / ZL-20 FEL Valve Comparison #11
That's the "block style" valve, same as I have on my loader. A complete POS in my opinion, and soon to be replaced. Either with Ronald's or Tommy's conversion kit or a DIY job using a Brand valve, but that crappy thing has to go.
   / ZL-20 FEL Valve Comparison #13
Rob, here are the pictures of the valve on my ZL-20 FEL. Richard
That was the same valve that came on mine. I upgraded back in 2004 to a Prince Valve.
Chris
   / ZL-20 FEL Valve Comparison #14
Get a kit. I did mine myself before the guys came up with the retrofit kits and it cost as much if not more to get the valve, make a bracket, and then get custom hoses. Plus it took time and was a pain in the ***.
Chris
Richard,
I guess you got the consensus from the group to change out that valve.
I sent you the link to Ronald's aftermarket valve kit which I put on Loretta's tractor. It is sweeet and super easy to install.
   / ZL-20 FEL Valve Comparison #16
Rob, Your guess is right. I'ed like to run this valve for a time before I bite that bullet. Richard
   / ZL-20 FEL Valve Comparison #17
On the six hose block valve which is the pressure in line? Click to enlarge.
   / ZL-20 FEL Valve Comparison #18
Hope the picture comes through / works ??
Ronald
Ranch Hand Supply
   / ZL-20 FEL Valve Comparison #19
Ronald, Thankyou! Richard
Rich, Took me a while to figure out what pos ment.
2019 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2019 CATERPILLAR...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
UNUSED CFG INDUSTRIAL SSFM81 FORESTRY DRUM MULCHER (A51244)
UNUSED CFG...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
