Zetor 3320 master cylinder
/ Zetor 3320 master cylinder #1
gerkey
Waycross,Ga
Zetor 3320
Could someone tell me where the right master cylinder is located or how toget to it. The pedal pushes down but does nothing, the left side will stop the left tire. So I am guessing it needs a new master cylinder on the right side. Any help is appreciated.
/ Zetor 3320 master cylinder #3
Call mark harper dba diesel doctor in russelleville, ky. Expert and dealer for zetor
/ Zetor 3320 master cylinder #4
get in by opening the hood and taking off the firewall. about an hour of work.
But if your tractor doesnt run out of brake fluid (which is also used by the hydraulic clutch, which will go out first because the suction line of the clutch cylinder is higher in the reservoir) its probably not leaking the fluid away and something else may be wrong.
