Zero turn vs. 4X4 tractor for mowing
   / Zero turn vs. 4X4 tractor for mowing #81
Depends on how steep and how the wetness affects traction.
Cub Cadet makes a line of zero turns with front wheel steering for slopes as well as another line that have decent slope mowing capacity. Not sure if you'd want to change out the turf tires for higher traction ones....
I suppose someone will ask why you don't buy a new rear PTO finish mowing cutter if everything else is working for you except for mower breakdowns? 7 acres is a lot of mowing any way you look at it. In most instances, cutting width determines mowing speed because you can only travel so fast on slopes without increasing the risk of rollover.
Another potential option to consider is one of the Power Tracs like the PT 425. T8 Class But it will take a lot of time to cut 7 acres with only a 4' cutter.
A zero turn can save time because it is easier to mow around obstacles, but if you are mowing open areas, cutting width is still going to be the primary factor in reducing your mowing time.
I have to agree that the most economical choice would likely be a high-end rear-mounted, PTO driven mower. You can choose the width that best fits your property and is within the power rating of your tractor.
  • Good Post
Reactions: JJT
   / Zero turn vs. 4X4 tractor for mowing #82
This site really does have a community that gives great feedback. I think you have already gotten great feedback. I think if you have a Ferris and Cub Cadet dealer near you it is time to demo them. Also I would highly recommend you step up to a Ferris ISX2200 Z as it comes with a true commercial engine if you go with the Vanguard 810cc. You will also get larger transaxles for faster mowing and an all around better longer lasting machine. Ferris really is the way to go for comfort hands down. Having that said, my Ferris is not good on slopes. I mow a lot of properties with slopes and it took me years to learn to mow with it and it is still dangerous.
As another user recommended you should also look at a steering wheel (Synchro Steer) Cub Cadet. They are much better on hills. You obviously need to be looking at the Pro Z line and not the residential big box steer line. I don't think I will ever own anything other than a Ferris because of the comfort but it honestly does leave something to be desired on hills. Sometimes I find myself spinning out on the the most embarrassing places, especially if wet. So if you plan to keep your butt on on your machines seat as much as possible for that 7 acres then the Ferris may have drawbacks.
   / Zero turn vs. 4X4 tractor for mowing #83
For the past ~10 years I have been using my Ford 1620 HST 4x4 with 60" 914 deck to mow about 7 acres. I'm at the point now where I don't look forward to mowing due to many mower deck breakdowns (tractor is great) along with the the time required to mow all 7 acres. It basically kills one whole day of my weekend. I think the top speed of the 1620 in MED gear (fastest I can go due to blade speed and cutting) is something like 1.5 mph.
I have been hesitant to get a zero turn due to the fact I have a decent strech of mowing along ditches & pond banks (~1200ft of pond banks, ~ 1000ft of ditches), where sometimes it can be a bit wet. I have never gotten my 1620 stuck to the point I needed another piece of equipment to pull it out. The rest of the mowing is very flat.
I have been looking at thie Ferris mower: Ferris 5902073
I assume my cutting time will decrease, but it also seems like I am going to not be able to cut some areas, especially on the steep ditches?
Sounds like you are describing my property! I too mow seven acres of mostly flat grass/mix with slopes around the pond and trees scattered throughout the property. I use a Kubota Z122EBR-48 to mow around the house, shop and fence line and a Kubota L3700 SU with a 6' finish mower for the larger open areas which includes 600+ feet of highway easement out front.
I read several posts that talked about getting their Zero-turns stuck and or sliding on hillsides and I too had that issue with my first Zero-turn which was a Huskavarna 42". It was constantly getting stuck on flat ground when a little damp and then started having hydraulic problems with the drive system. I convinced my least favorite brother-in-law that he needed it more than I did and I bought the Kubota. (LOL) I don't want to sound like a Kubota salesman but I can't tell you how much different it was going from one to the other. The Kubota is much more comfortable to run and has only been stuck once in 7 years when I ran it into mud that was so deep the deck was plowing mud.
People ask me why I mow seven acres and I can only justify it by the fact I was a military brat who also served in the military and a fireman for nearly 40 years, it's in my DNA lol.
   / Zero turn vs. 4X4 tractor for mowing #84
Damn! Even at 2 acres/hour, that's a lot of hours.
I mow every 4th day in spring, trailing off to weekly for most of the season after that, except a little break we usually get in the July heat and drought. Mowing every 4th day at 15 hours/mowing would be 4 hours per day on average, for 30 acres. :oops:
The front 15 acres takes me 3 1/2 hours but its an open field. We mow it about every 2 weeks in spring. Around the house and buildings (5 acres) more frequently. And the remaining (minus buildings, arenas, drives) is in paddocks that are mowed as needed to neaten them up. So... not to bad.
Ferris is known for the comfortable ride. I do use the seat belt, lol.
It gives a great cut. Love the machine. Only negative thing I would say is that the underside of their mower deck holds to much grass. Probably could be designed a little better. Other ZTR we've had haven't held as much.
   / Zero turn vs. 4X4 tractor for mowing #85
My two cents (now 5 cents due to tariffs [govt taxes])...
A gas-powered zero-turn is going to burn a lot more fuel than what you're used to, a diesel.
A 6' side-shift flail may be a solution: might have to go 5'. You can mow near edges pretty well with a side-shift. I find that my flail mows around trees very well. Also not too bad mowing around fences but the side-shift has me all too often playing chicken with the fence: spend the time with the trimmer or repairing fencing, seems there's no win here!
I've contemplated a zero-turn for around the house but cannot justify it (I'd want a diesel - $$$) so I just continue to use my riding gasoline mower for most of this. I've also contemplated a small flail for my B7800.
I probably mow somewhere around 25 acres in total*. Ditches, trees, fencing and even a pond. Some areas with slopes but not very significant.
*Because? Because it keeps me off the streets!
   / Zero turn vs. 4X4 tractor for mowing #86
Everyone has strong opinions on this topic and is pretty well set in their position and unlikely to be swayed.
I fall into the ZTR camp. I've been mowing with mine for 20 years and am very pleased with the speed and cut quality. Much better than a tractor or rider. I do have fairly steep pond banks and have successfully learned to mow them by actually using the tendency of the mower to slip down the hill. It's a bit sketchy until you get the hang of it and I'm not recommending it. Just saying it can be done. As for getting stuck I don't mow the pond if it's at all wet but do sometimes mow the flat areas before they are completely dry and that's the only times I've been stuck. Easy to pull out with anything that can get traction. I have used my tractor, gator, and small SUV.
Maybe keep mowing the steep banks as you have but get a ztr for the flats. I would guess you'll cut your mowing time by 30 percent, maybe more once you get used to it.
   / Zero turn vs. 4X4 tractor for mowing #87
I have that exact mower and cut about 17 acres. I can cut at full speed, significantly faster than your tractor. I can do 17 acres in about 5 hrs. As far as ditches and steep banks, this tractor is heavy. Its a pro zero turn. Its not really meant to cut steep banks and it gets sketchy AF close to the edge of a ditch (we have about 1200ft ditch) on wet grass. Again its heavy so wet grass we dont mow. period. We bought mud rear tires that help a little bit with the wet areas that we can get stuck in but we just stay out of the wet areas in the spring so we dont dig up the grass or get stuck. Its a dream to ride tho - VERY comfortable. 7 acres is probably 2-3 hrs not even a full tank of gas. Just stay out of the wet and give the ditch and the steep banks a wide path and youre good.
   / Zero turn vs. 4X4 tractor for mowing #88
The only thing I would add to these many fine comments is to consider who is going to service the deck (lube, blade sharpening, and cleaning). If that is you, make sure you are comfortable with what is involved in your final choice(s).
   / Zero turn vs. 4X4 tractor for mowing #89
I would look at a new mower attachment instead of a ztr. Losts of moving
Parts on zero turn you maybe back to breakdowns in a few years. I have a similar setup
with a rear discharge finishing mower and love it
   / Zero turn vs. 4X4 tractor for mowing #90
When we had flat, minimal obstructions the 60" finish mower worked fine behind our 4220i branson. Now we more challenging terrain and obstacles. Ended up selling the finish mower and bought a Diesel kubota ZD326 ZRT with 60" deck. Added Carlisle WT300 traction tires and we love it. The dry side of pond bank is 30* and I can mow it....wife will not. It is sketchy but will do it. I've considered doing the front brake upgrade to it over the years. Liquid cooled diesel engine is so much quieter than a gas ZRT.
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
NEW Landhero Mini Excavator (A59000)
NEW Landhero Mini...
Terms and Conditions (A55272)
Terms and...
Caterpillar 262D3 (A57148)
Caterpillar 262D3...
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
2005 Isuzu NQR 4 door box truck with folding gate (A56435)
2005 Isuzu NQR 4...
