Zero turn Cub Cadets
/ Zero turn Cub Cadets #1
ceckard
I'm mowing 2 acres of ground, some rough , some lawn will it do the job. 54" 24 HP from Home Depot
/ Zero turn Cub Cadets #2
Try to look at something with a longer wheelbase, the Cubs are choppy and uncomfortable on rough ground. Look at Bad Boy and Grasshopper. If you go with Cub, make sure you get a model with a Kohler if possible.
/ Zero turn Cub Cadets #3
The only RZT series I would purchase is the 54" model. That one comes with the Hydrogear ZT-2800 transmissions. The lesser models come with the EZT transmissions, which have had lots of problems in the Cubs. However, you would probably be better served moving up to a Cub Z-Force series. In addition to the better transmissions, they have several other improvements that make it a better product, including a much better performing mower deck.
Z-force's are only sold by Cub dealers, btw.
Bad Boys and Grasshoppers are nice products too, but you will pay a lot more for them. If you can swing it, you may be happier in the long run with one of them. If not, then the Z-Force's are probably the best bang for buck out there.
/ Zero turn Cub Cadets #4
Given this usage, I wouldn't go that route.
I owned a 2010 model year Cub Z-Force 44" with the fabricated steel deck. A nice machine, but they're meant for lots of level and smooth lawn. If you don't have 'lots, level and smooth', don't go Cub ZTR.
Joel
Thanks for advice will look for other options .ceckard
/ Zero turn Cub Cadets #6
I own an RZT 54 with a 24 hp Kawasaki engine. I really like it. It is pretty rough on the bumps though. A suspension seat would cure that though. I have over 60 hours on mine and the only problems I have had dealt with a rattling deck, which was cured by installing new washers on the deck bolts. For the price (<$4000), I think the RZT 54 is a great buy. The Bad Boy zero turns are definitely beefier though. I was impressed with their construction. However, you will pay for it...
/ Zero turn Cub Cadets #7
Also, forgot to mention that the RZT 54 has a front, greasable suspension pivot point, which does help on uneven surfaces.
UNUSED IRANCH IRTPL 10000 LB TWO-POST CAR LIFT (A64281)
UNUSED IRANCH...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
Muck-Truck Wheelbarrow (A61567)
Muck-Truck...
