Zerks and tears
/ Zerks and tears #21
Hmm, I don't think I've had to replace a zerk on my equipment for 30 years. I have a big supply of zerks just in case too.
Same here, never replaced one, and never really have a problem with zerks taking grease. Certainly no tears. :)
/ Zerks and tears #23
I got lucky.
A buddy, who likes to wheel and deal, bought many cases of synthetic grease at a bargain lot price.
He nicely let me have a couple of cases @ $10 per case of 12. so I'm OK for quite a while.
PS, he's the same guy that gifted me ($25) a Lincoln power grease gun*, (The one that was so baked hard that I had to pry out the dry clay base grease)
*@ $25 I considered that a gift!
/ Zerks and tears #24
Get an electric grease gun, you won’t regret it. I’ve never had a zerk that wouldn’t take grease, I must be lucky. My pet peeve was getting a new cartridge started on a manual grease gun.
Ha! I might dread putting in a new grease cartridge more than going to the dentist!!!
MoKelly
/ Zerks and tears
I did replace grease gun tip and got the last 4 zerks. I’m never sure how much to pump into universals.
I greased tractor often so don’t normally have any issues with that. But I am getting locked up solid on front axle pivot point. It’s not the tip or the zerk as no leakage. Not sure if I can put heat gun on it for a minute if that would help. The atv was the battle
/ Zerks and tears #28
Some tractors notably Kubota's have a grub screw you remove and you pump grease until it comes out the grub screw hole.
/ Zerks and tears
Yeah this one just has the zerk. But none escapes the zerk or tip. And can’t get a pump in at all. Anything go hurt if I warm up with a heat gun. What Type of bushing is there?
/ Zerks and tears
The front wheels of my John Deere have to be off the ground before grease will go in that pivot point.
Yeah I tried that too. Even pivoting while pumping. Though I might try it again this evening.
/ Zerks and tears
Yes they make greasing go faster.
They don't fit every fitting due to the diameter and length but they fit the vast majority of grease fittings.
I might have had to replace a zerk fitting that would not accept grease once. It's rare. Sometimes on tractors the force on the part can keep grease from flowing. You can move parts around to get the weight off and let the grease flow.
Yeah like Quebecguy stated he had to lift the front wheels off the ground to grease the pivot point on front axle. I tried that too. Might try again though and really pivot the axle. I barely had the wheels off the floor
/ Zerks and tears #33
If I have a zerk that won't take grease, I use a steel wire brush that painters use on the face of the zerk. Frees it up and you are god to go.
/ Zerks and tears #35
I’ll have to look at the grease us used today. It’s white motor master grease. I got most of them after hours long battle. But still have the universals go do. How much grease you put in those? I lose so much around zerk it’s hard to know if any is getting in. I was awful tempted to buy electric grease gun today. See how greasing goes next time first.
brother-in-law bought a dewalt battery power grease gun for his dozer. on a couple the pressure relief on grease gun activated and grease came out of it, in other words didnt neccess work. Still had to replace part of them.
/ Zerks and tears #36
When I have a zerk that won't take grease i use one of these
I bought one of those about 20 years ago, I've probably tried it a dozen times and when I'm done I still have a plugged fitting but now I have a big mess too. They sure look good in the advertisement video.
/ Zerks and tears
Yeah it wasn’t so much about getting in easier with the electric. But more to do with it’s easier to fiddle with grease gun tip while pressing a button than wrestling with a pump handle in awkward spots. But I think I have all but one on the tractor giving me an issue now so I’ll keep with the manual. Might need to warm this one up. Pivot point on front axle , I removed the nipple but still can’t get any in. Not sure if I missed that one or what but the tractor I greased pretty often do grease squeeze out of that no issue. But can’t get it in that one at the moment. None leaks out either from zerk/ gun
/ Zerks and tears #38
I bought the Dewalt (20v) greaser. Put a zerk clamp-on connector on the hose. It clears "most" of my Zerks and gets grease in.... not all however. But, the manual guns were giving me fits especially when I was standing on the tires, doing the front-end loader zerks.
/ Zerks and tears #39
I thought I had a bunch of stuck zerks but turns out my lever style gun stopped pressing grease. For the life of me I can’t seem to figure out what’s wrong with it. They’re cheap enough that I’ll just buy a new one, but the frugal mechanic in me makes me reluctant to throw away something that likely can be salvaged.
/ Zerks and tears #40
I work on a lot of older forestry equipment and bucket trucks. It is common place to find a few neglected grease fittings. I've tried the hammer type grease busters
and the lock on grease tips. What I've found that works for me is to use a good quality hose on the end of your gun with a working pressure of 6-8000Lbs or more.
When I run into a fitting that won't take grease, even when holding it on the zerk, I take the zerk off and put on a new one. If that doesn't work I take off the hose
on the end of the gun and put on a hose that i blew out most all of the grease and fill it up with PB Blaster. I put the hose back on the gun and squirt it in. It may
take 2 or 3 shots of this to loosen up the old grease. I then move whatever the fitting is trying to grease up and down or rotate a few time in both directions and
then grease it. Had best luck doing it this way. The worst one I ever had, I had to heat up the joint and put the PB Blaster to it 3 or 4 times before it would take
grease, but it did. Like I say, this works for me.
Case 1845C Skidsteer Loader (A66285)
Case 1845C...
Forklift Man Lift Safety Cage (A66408)
Forklift Man Lift...
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
Welcome to the Ranch Metal Sign (A65583)
Welcome to the...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A64194)
2015 Peterbilt 348...
Sunflower (A64557)
Sunflower (A64557)
