Zerk Spits Out Grease
   / Zerk Spits Out Grease #1
LouieJunior
Platinum Member
Moline, Illinois
JD4052R Open Station
I have a flail mower -- three or four years old -- and one of the rotor grease fittings will not accept grease. After I pump the grease gun a few times and remove from the zerk, the grease comes shooting back out -- like from a can of cheese-whiz.
I removed the zerk and it seems okay. Any suggestions on what's going on? The rotor spins fine and the mower continues to cut nicely.
   / Zerk Spits Out Grease #3
Yes, put on a new zerk. Old one has been damaged and is not sealing properly. Like katoomed00 said.............
   / Zerk Spits Out Grease #4
Heres a cutaway drawing of a grease zerk ball check.
   / Zerk Spits Out Grease #5
Sometimes you can free it up. I hate replacing zerks- always stripping one, getting the wrong size - etc.
Confirming problem was the zerk. I couldn't locate a 6mm metric replacement so I traded zerk with another on the mower and greased the rotor bearing. I will order a replacement now. Thanks all!
   / Zerk Spits Out Grease #7
H.F. has kits in S.A.E. and Metric . I have used them for years on my k.k. disk , N.H. mower , N.H. Backhoe and even on my semi's without a issue . Last semi truck had a new slack adjuster on front right steer . Whoever put it on forgot to pull the plug and put in a zerk . Replaced plug with a H.F. metric from the kits and it still worked fine 4 years later and something like 400,000+ miles .
Fred H.
WESSEX 1.5T LOT NUMBER 172 (A53084)
WESSEX 1.5T LOT...
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
1982 MACK RD685S HOTOILER (A52472)
1982 MACK RD685S...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
2012 DOOSAN G25 GENERATOR (A52472)
2012 DOOSAN G25...
