Zerk Spits Out Grease
   / Zerk Spits Out Grease #1
LouieJunior
Platinum Member
Moline, Illinois
JD4052R Open Station
I have a flail mower -- three or four years old -- and one of the rotor grease fittings will not accept grease. After I pump the grease gun a few times and remove from the zerk, the grease comes shooting back out -- like from a can of cheese-whiz.
I removed the zerk and it seems okay. Any suggestions on what's going on? The rotor spins fine and the mower continues to cut nicely.
   / Zerk Spits Out Grease #3
Yes, put on a new zerk. Old one has been damaged and is not sealing properly. Like katoomed00 said.............
   / Zerk Spits Out Grease #4
Heres a cutaway drawing of a grease zerk ball check.
   / Zerk Spits Out Grease #5
Sometimes you can free it up. I hate replacing zerks- always stripping one, getting the wrong size - etc.
Confirming problem was the zerk. I couldn't locate a 6mm metric replacement so I traded zerk with another on the mower and greased the rotor bearing. I will order a replacement now. Thanks all!
   / Zerk Spits Out Grease #7
H.F. has kits in S.A.E. and Metric . I have used them for years on my k.k. disk , N.H. mower , N.H. Backhoe and even on my semi's without a issue . Last semi truck had a new slack adjuster on front right steer . Whoever put it on forgot to pull the plug and put in a zerk . Replaced plug with a H.F. metric from the kits and it still worked fine 4 years later and something like 400,000+ miles .
Fred H.
Lift Gate (A52377)
Lift Gate (A52377)
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
