Zerk Spits Out Grease
   / Zerk Spits Out Grease #1
LouieJunior
Platinum Member
Moline, Illinois
JD4052R Open Station
I have a flail mower -- three or four years old -- and one of the rotor grease fittings will not accept grease. After I pump the grease gun a few times and remove from the zerk, the grease comes shooting back out -- like from a can of cheese-whiz.
I removed the zerk and it seems okay. Any suggestions on what's going on? The rotor spins fine and the mower continues to cut nicely.
   / Zerk Spits Out Grease #3
Yes, put on a new zerk. Old one has been damaged and is not sealing properly. Like katoomed00 said.............
   / Zerk Spits Out Grease #4
Heres a cutaway drawing of a grease zerk ball check.
   / Zerk Spits Out Grease #5
Sometimes you can free it up. I hate replacing zerks- always stripping one, getting the wrong size - etc.
Confirming problem was the zerk. I couldn't locate a 6mm metric replacement so I traded zerk with another on the mower and greased the rotor bearing. I will order a replacement now. Thanks all!
   / Zerk Spits Out Grease #7
H.F. has kits in S.A.E. and Metric . I have used them for years on my k.k. disk , N.H. mower , N.H. Backhoe and even on my semi's without a issue . Last semi truck had a new slack adjuster on front right steer . Whoever put it on forgot to pull the plug and put in a zerk . Replaced plug with a H.F. metric from the kits and it still worked fine 4 years later and something like 400,000+ miles .
Fred H.
2020 VOLVO VNL SLEEPER (A52576)
2020 VOLVO VNL...
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
2020 Nissan Pathfinder SUV (A51694)
2020 Nissan...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
2012 CHEVROLET 3500HD SILVERADO LS DUALLY TRUCK (A51247)
2012 CHEVROLET...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
