ZEN-NOH YM1500
/ ZEN-NOH YM1500 #21
I suspect California has zeroed in on what happened.
/ ZEN-NOH YM1500 #22
The people who owned it before made a connection on the side with one male and one female remote coupler and that circled the fluid through the loader. I disconnected these from the loader when I removed it, however I did not immediately connect them back together completing the circle. I wonder if this had anything to do with it? Did it damage the pump by me not connecting them back up immediately. The tractor was running at the time as well, so I don't know if that had anything to do with pressure or not. When I disconnect the remotes now (as I did to evaluate things to the best of my ability) there was no apparent pressure on the output coupler because I could depress the inside nipple with no problem. This has stress me out somewhat because I priced the new hydraulic pumps and they are quite substantial in price, not to mention the tedious process of changing it out is somewhat daunting.
/ ZEN-NOH YM1500 #23
Hopefully you only sheared the key on the pump shaft. Although not shown on this drawing there is a key under the drive coupling. If you cannot see any external cracks in your pump then you will have to pull it and further investigate. These pumps have to have a place for the fluid to go. Never crank up without making sure that is so. HYDRAULIC_SYSTEM: Yanmar Tractor Parts
/ ZEN-NOH YM1500 #24
Thanks for your input. It is greatly appreciated.
/ ZEN-NOH YM1500 #25
I don't see any cracks on the outside of the pump at all. It looks like I will have to pull it to see if the key is sheared. Is it common for this to shear in situations I just described? If so, that is a great safety feature to protect the pump from damage.
/ ZEN-NOH YM1500 #26
Has happened many times. That is if your lucky. :)
/ ZEN-NOH YM1500 #27
They do have a key that can sheer.
But sounds like you dead headed the pump. Like Winston said, hopefully that a key was sheared at that was all. Cause pumps last forever usually and are expensive.
/ ZEN-NOH YM1500 #28
I really appreciate everyone's input. I am not an expert whatsoever on hydraulic systems. So basically, I remove the pump and see if the key was sheared. If it was, will it be just laying around inside the pump somewhere? Is the process just simply replacing the key and putting the pump back on?" When the pump is removed, how would I tell if the pump is bad? Sorry for all the questions, however I wish to proceed upon this venture with all the knowledge I can possess. Thank you!
/ ZEN-NOH YM1500 #29
I am far from an expert as well. But if everything is hooked up right and it does not work there is a good chance the pump key has sheared or blown up. A loose quote from Aaron at Hoye Tractor..."those things rarely" just go out. Now I don't want to totally speak for him bUT that was from some messages we sent back n forth like a decade ago when I had some hydro issues.
/ ZEN-NOH YM1500 #30
Half of the key would be in the pump shaft, the other half in the pump coupling. If the key is sheared it would be likely the pump would be ok. Replace the key, reinstall the pump.
/ ZEN-NOH YM1500 #31
I have another question for someone if you don't mind. Since I do not possess an owners manual for this tractor I was curious as to the correct functionality of the PTO lever. I have never owned a tractor that has a multi-speed shaft before. It is not denoted whatsoever which position is what speed and I do not want to risk damaging any of my equipment, so I thought I would inquire. All of my PTO equipment is 540. Any assistant would be greatly appreciated.
/ ZEN-NOH YM1500 #32
1st. gear is 540. All US. implements use this gear. You can run pretty much wide open. 2400Eng. RPMs. I also have multiple speeds 3. Which I had trouble with. But I can now keep 2nd PTO. locked in gear. I use it with my US. Finish mower. A Frontier JD./Woods. And to get 540 in 2nd. is only 1750 rpms. Eng. Speed. 3rd I can use but don't and never messed with except when I was checking to see if it also worked.
/ ZEN-NOH YM1500 #33
Original parts manual states 639, 828, 1097. I would assume that at maximum rpm of 2400. If that is so 540 would be achieved at 2028, 1565, 1181 rpm.
You can buy one of these if you want to zero in. Search results for: 'tachometer'
/ ZEN-NOH YM1500 #34
The gears are not marked first, second, third. Which position is which gear?
/ ZEN-NOH YM1500 #35
Another alternative I like is the old-school Briggs & Stratton #19200 mechanical tach. About $20~25 mailorder, half that (used) on Ebay. Indestructible, so used should be fine.
You touch it to the object to be measured so it senses vibration. Then rotate the top dial which extends the yellow wire out. When the wire resonates, vibrates, you read rpm on a scale that corresponds to how far the wire is out. Its surprisingly precise, it matches the Yanmar dashboard tach.
/ ZEN-NOH YM1500 #38
1st all the way down. Neutral next up. Next up. 2nd. up 3rd.. I'm glad I don't have to tell you how to shift a 2500. It has 2 shift levers which I can't tell you for sure which is what.. :confused2:
/ ZEN-NOH YM1500 #40
I went to the Hoye website and found the decal 4190 that you mentioned, and yes, that is exactly what I was looking for. I was also attempting to understand each gears PTO speed, but I think "careo63" clarified that for me. Thanks everyone!
