Mowing ZD323 blades pricing
/ ZD323 blades pricing #1
rglaser
Waynesville, Ohio
Kubota B2630 & ZD323
I got a quote on a set of replacement blades from my local dealer of about $70. That seams pretty high to me, what do you all think?
Thanks,
Rob
/ ZD323 blades pricing #2
Thanks,
Rob
We had tried to use other make blades then the Kubota blades and our customers found faster wear, or shorter life some times less then half. The steel used in their blades makes them one of our better units for long life blades.
Being a multi line dealer and being able to compare them with other makes they are not over priced.
I didn't get any shocked responses so I am going to assume that is an ok price and pick them up.
Thanks.
/ ZD323 blades pricing #4
I wish I knew, but I haven't had to purchase any as of yet... Sorry I'm no help.
/ ZD323 blades pricing #5
I think that price is reasonable for good quality steel. Try owning a Patu Wood Chipper; it's has 3 blades which cost $130 a piece to replace.
/ ZD323 blades pricing #6
I don't know if they have exactly what you are looking for, but Agri-Supply :
Kubota
carries blades for what seems like everything (at least to me). They seemed cheap to me when I bought some for my general riding mower, but I can't tell you if the steel is really any good or not. So far they have been ok on my moderate yard (Craftsman mower though).
Might be worth a check. Maybe others here can say if they will wear out sooner like the above post implied.
/ ZD323 blades pricing #7
I just bought 3 gator blades for my ZD21.They cost me $84 dollars at the local dealer.I saved the number offf the new blades and going to see if I can find them cheaper online.
Thank you all for the responses. I think I paid a bit more than I could have gotten them from other sources but I went ahead and bought them from my local dealer. Now I need to figure out how to remove those 30mm nuts! I was thinking a fairly strong impact wrench. How do you all remove and replace yours?
Thanks again for the great info.
-Rob
/ ZD323 blades pricing #12
I use an electric impact wrench.
kj
/ ZD323 blades pricing #13
Only mowed three times with my ZD323 so far, so I haven't needed to change blades. But I usually use an air impact.
I had Gators put on before I picked it up. They gave me the OEM blades to take home so I can't compare and say if they they made a difference or not. But I can say it cuts better than anything I've used before.
YALE FORKLIFT (A63291)
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
ELECTRIC MOTORS WITH PUMP (A65643)
ELECTRIC MOTORS...
Power command Transfer Switch (A62679)
Power command...
2020 WESTERN STAR  4900 TRI AXLE (A65643)
2020 WESTERN STAR...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
