Z920A Starter
/ Z920A Starter #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
After the outbuilding was finally accessible, I tried starting the Z920A mower.
It started right up, but I shut it right down since I wanted to open the overhead door.
Restarting, I'm just getting a ratcheting sound...and I'm pretty sure it's the starter Bendix not fully engaging.
Anyone had this problem? You think tapping the starter might work? I hope I don't have to replace it...and hopefully someone more mechanically inclined then I am will chime in...
/ Z920A Starter #2
check battery, tapping on starter won't hurt it
/ Z920A Starter #3
I agree check for corrosion on the cables and test the battery voltage. My exmark has the bendix on the side of the frame, not built on to the starter. If you can find the bendix try jumping a wire across the terminals and see if it cranks.
/ Z920A Starter #4
I'd think "low battery" first off. Once started, let them run for awhile before shutting down.
/ Z920A Starter
Thanks for the answers, guys!
It seems like it's cranking fast enough to eliminate the battery, but I'll try charging it this week.
/ Z920A Starter
You guys were right! Battery didn't have enough charge to engage the bendix. I charged to battery today and it's starts right up! Ran the mower around for about 10 minutes.
Thanks, Guys!!
/ Z920A Starter #7
Glad it was a simple fix. Let's just hope the battery holds it's charge , those little battery's have about doubled in price in the last few years.
GREAT PLAINS 1006NT - 1575 NO-TILL GRAIN DRILL (A64277)
GREAT PLAINS...
Lesco 50Lb Push Spreader (A64557)
Lesco 50Lb Push...
2005 Chevrolet Silverado 2500HD Duramax Diesel (A66408)
2005 Chevrolet...
2026 Electric Tricycle (A64194)
2026 Electric...
2011 International 4300 Versalift VST60001 65ft. Insulated Bucket Truck (A64194)
2011 International...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
