YT359c top link!
/ YT359c top link! #1
RadarTech
Elite Member
North Carolina
2007 Kubota L3400, YANMAR YT359C
I don’t remember who else was looking for info about the Hudraulic Top link for a YT359c…
But mine came in.. and was on and working in less than 20 min..
I got it from Agristoreusa .com
Top link SKU 06004. 20 7/8 to 31 7/8
I got this length as the 27" max on the factory one was too short with the pat's easy installed..
And the hoses were SKU. E000050915
This is 1/2 in valve couplers.. 2 ft hoses. and it all fit fine..
I used Agristore since summit is backordered until August. Or September when I went to order.
I hope this helps someone..
Looking back I see now that summit only has the hosed and parts backordered the cylinder is not ..
But agristore has FREE shipping..
/ YT359c top link! #2
I did the same.. I did need hydraulic restrictors to slow the cylinder and stop the chatter when there is a heavy load on the top link as it extends. Seems pretty common.
/ YT359c top link! #3
Thanks for posting this. I got mine from Summit Hydraulics. I ended up going with the next length longer. The one that matched, would tilt my attachments way forward,…but not as far as I needed when it’s extended.
Will have to consider one as well. I have the chatter too, and it is annoying.
/ YT359c top link! #6
Where did you get those restrictors?
Well, the cylinder was Italian, so I did end up buying them from across the pond for the correct thread type and pitch.
They were a few bucks each. Let me find my post about them.
/ YT359c top link! #7
Around post 75 I talk about what I used. If you bought from AgriStore, you'll need BSP threads and MOST of what you'll find here is NOT.
/ YT359c top link! #16
Will have to consider one as well. I have the chatter too, and it is annoying.Hi
/ YT359c top link! #17
Hi RadarTech,
Thanks for your post. I am in the process of buying an open station Yanmar YT359 and wanted the top n tilt. Your post should be what I need for the top. Are you happy with the choice. Is the quality and function what you would recommend? Summit is back ordered to Oct 2024. I would appreciate your comment on this.
/ YT359c top link! #18
Hi Desertsasquach,
I would appreciate knowing what you decided on as I am a bit new to this and want to get a top n tilt for an open station YT359. I don't know what the "next longer length" item would be when looking at the top kits. Also would like to know what restrictors I would need. Just learning about this, so a little confused.
/ YT359c top link! #19
Hi Desertsasquach,
You would be better off with 2 1/2" dia cylinders and 1 1/2" dia rods IMO.
That is what I recommend for your model, similar to those pictured.
If you are not using Pat's quick hitch, then you want something with a working length close to 20"-29" for a top link.
Side link should be built to provide an equal amount of tilt angle to both sides using a 5" stroke cylinder.
You can get a quote here if you like.
/ YT359c top link!
Hi RadarTech,
I do like it.. I need to buy a hydro limiter though.. I’d recommend you get one..
UNUSED ATSPOWER 40 GALLON AIR COMPRESSOR (A64281)
UNUSED ATSPOWER 40...
7102 (A61567)
7102 (A61567)
(INOP) JOHN DEERE 694 CORN HEAD (A63291)
(INOP) JOHN DEERE...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
UNUSED ATSPOWER PROPANE PATIO HEATER (A64281)
UNUSED ATSPOWER...
2019 Ram 3500 4x4 Service Truck (A61573)
2019 Ram 3500 4x4...
