YT235 PTO brake?
   / YT235 PTO brake? #1
Gypsyman
Quincy, FL
2020 Yanmar YT235C
Can anyone tell me if the YT235 has a built-in PTO brake?
I just added a Wood Maxx WM-8H chipper to the other heavy rotating implements I have and I’m concerned that the 200 pound flywheel on that unit may require the use of a PTO clutch. If it doesn’t require the use of one I’d rather keep things simple and save the driveline length.
I can’t find anything in the manual and I can’t seem to get anyone at Yanmar to return my calls.
Any insight would be greatly appreciated.
   / YT235 PTO brake? #2
For something like that you will need what is called a slip-clutch. It is installed on the implement's PTO driveline.
   / YT235 PTO brake?
I’m familiar with the slip clutches but this unit already comes with a shear bolt for excessive load. I’m more concerned with the weight of the flywheel causing access wear to the PTO brake if the tractor has one installed.
   / YT235 PTO brake?
Just as I hit send my phone rang. It was Yanmar Support. According to them the YT235 does not have a PTO brake so no overrunning clutch is required. Hopefully that’s correct information. It could get spendy if that’s incorrect.
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2020 Toyota Tacoma Crew Cab Pickup Truck (A59230)
2020 Toyota Tacoma...
1999 Thompson H3 S/A Towable Vacuum Water Pump (A59228)
1999 Thompson H3...
WET LINE TANK (A60432)
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
