YT235 PTO brake?
/ YT235 PTO brake? #1
Gypsyman
Quincy, FL
2020 Yanmar YT235C
Can anyone tell me if the YT235 has a built-in PTO brake?
I just added a Wood Maxx WM-8H chipper to the other heavy rotating implements I have and I’m concerned that the 200 pound flywheel on that unit may require the use of a PTO clutch. If it doesn’t require the use of one I’d rather keep things simple and save the driveline length.
I can’t find anything in the manual and I can’t seem to get anyone at Yanmar to return my calls.
Any insight would be greatly appreciated.
/ YT235 PTO brake? #2
For something like that you will need what is called a slip-clutch. It is installed on the implement's PTO driveline.
/ YT235 PTO brake?
I’m familiar with the slip clutches but this unit already comes with a shear bolt for excessive load. I’m more concerned with the weight of the flywheel causing access wear to the PTO brake if the tractor has one installed.
/ YT235 PTO brake?
Just as I hit send my phone rang. It was Yanmar Support. According to them the YT235 does not have a PTO brake so no overrunning clutch is required. Hopefully that’s correct information. It could get spendy if that’s incorrect.
8ft. Fork Extensions (A59228)
8ft. Fork...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2013 Ford Focus Sedan (A59231)
2013 Ford Focus...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A59230)
2012 Ford F-550...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A59228)
2024 AGT LRT23...
2007 JLG 600S Manlift (A61166)
2007 JLG 600S...
