Yt 359 steering
/ Yt 359 steering #1
chevyman29
Bham AL
JD 2520
First let me start off by saying overall I'm really happy with this tractor.
But , has anybody figured out the fix for the steering ? If the front wheels are in the least bit of a bind it just won't turn .
Or if you have a load on the bucket .
Yes the front tires are filled with liquid. No squatting or half flat front tires.
Also it doesn't matter if the RPM is idle or wide open .
The least bit of a bind or a load and it's just not turning if your sitting still.
If I didn't have a jd 4520 sitting next to it that works fine I might not think nothing of it.
Dealer was no help .
I read about the issue from someone on this site , but I noticed it didn't seem to be wide spread.
/ Yt 359 steering #2
I have 18 hours on mine, and easily 14 of it doing loader work moving heavy wet clay and 57 limestone. I have not experienced any issue with the power steering
/ Yt 359 steering
I appreciate the reply . Thank you.
That gives me hope that maybe it's something simple on mine.
When I get home I'll post up a video showing the issue
/ Yt 359 steering #4
my yt 347 does the same thing.
/ Yt 359 steering #6
I’ve had my YT347 for over 5 years and it has happened a few times to me. I alway have 1k lbs ballast on the back, maybe that prevents it.
Thats not my main issue with the tractor, it’s the frequent regens.
/ Yt 359 steering
That's a good point about the ballast wich I'm a firm believer in.
I've not had a Regen yet . But I've got maybe 20 hrs.
One thing I noticed the other day while using the auger , the boom on the auger will hit the rear remote valves if you lift it all the way up. Just by sheer luck I didn't kill mine the first time I raised it.
Just poor design on the placement of the valves.
Brent 420 Grain Cart (A63688)
Brent 420 Grain...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
2018 Ford F250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F250 4x4...
2015 Ford F-150 Pickup Truck (A62613)
2015 Ford F-150...
(INOP) 2022 MACK MD6 WATER TRUCK (A65054)
(INOP) 2022 MACK...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
