YQM-48 belly mower
/ YQM-48 belly mower #1
runningbird
Gisela, AZ
yanmar 1110d ,fx28d
does anyone know if the yqm-48 mower will work on a 135d? it is supposed to fit the 155 but I think the 135 is the same size.
thanks
/ YQM-48 belly mower #2
Went through my manuals. Only one I found with the YQM-48 mower has the YM165 and YM165D as the primary....inside the cover it says it will also fit a YM186 and YM186D, also a JD 650, Satoh Beaver III, etc.
Also says "and many other compact diesel tractors with 1 3/8" SAE 540 RPM PTO and Compact Diesel CAt 1 3-point hitch"
The other 2 manuals I have showing the 135 and 155 are for a YMM45 mower deck.
Hopefully some of the other yanmar guys will be of better help.
/ YQM-48 belly mower #3
It will fit the YM135. if it will fit between the wheels. The wheel base of the YM155 is 3" longer than the YM135. The tubes from the 3 point should have several holes to adjust to different tractors. You may be limited on how high it will lift, because it may hit the wheels.
Loudo Trailers 20ft. T/A Utility Trailer (A64557)
Loudo Trailers...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2022 EZ-GO ELITE...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
(2) RIMS FOR 10 LUG HUBS (A64278)
(2) RIMS FOR 10...
