Your towing rigs and trailers
   / Your towing rigs and trailers #2,585
The trailer weights 7,000 pounds and has 12k axles. There was nothing wrong with the PJ trailer. I use a trailer daily with my rental business and wanted the extra weight capacity for safety and to be able to carry 2 excavators at the same time.
Thanks for checking it out.
   / Your towing rigs and trailers #2,586
What kind of class license is required to pull this fully loaded?
   / Your towing rigs and trailers #2,587
Nice setup. Good idea on the wood deck so you aren't inclined to have to protect the deck each time you set a blade or bucket down. I had an aluminum deck once and I was always stressing about messing it up.
Did you go with the electric over hydraulic disc brakes? I went that route with my new Diamond C with 12K axles and it sure stops nicer than the normal electric brakes.
   / Your towing rigs and trailers #2,589
I went with electric over hydraulic. Can lock up all 8 tires with power setting above 6. Had to rewire the tow vehicle to get a 10 gague wire back to the actuator.
   / Your towing rigs and trailers #2,590
couple recent ones
dad;s suburban with his new JD 2210
my extra truck towing ~9000 lbs for some baseline numbers after adding a trans temp gauge
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2000 Chevrolet C2500 Ext. Cab Pickup Truck (A55852)
2000 Chevrolet...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55853)
2023 Fat Truck...
2005 Kaufman Trailers Car Hauler Trailer (A53421)
2005 Kaufman...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
