Your towing rigs and trailers
   / Your towing rigs and trailers #2,585
The trailer weights 7,000 pounds and has 12k axles. There was nothing wrong with the PJ trailer. I use a trailer daily with my rental business and wanted the extra weight capacity for safety and to be able to carry 2 excavators at the same time.
Thanks for checking it out.
   / Your towing rigs and trailers #2,586
What kind of class license is required to pull this fully loaded?
   / Your towing rigs and trailers #2,587
Nice setup. Good idea on the wood deck so you aren't inclined to have to protect the deck each time you set a blade or bucket down. I had an aluminum deck once and I was always stressing about messing it up.
Did you go with the electric over hydraulic disc brakes? I went that route with my new Diamond C with 12K axles and it sure stops nicer than the normal electric brakes.
   / Your towing rigs and trailers #2,589
I went with electric over hydraulic. Can lock up all 8 tires with power setting above 6. Had to rewire the tow vehicle to get a 10 gague wire back to the actuator.
   / Your towing rigs and trailers #2,590
couple recent ones
dad;s suburban with his new JD 2210
my extra truck towing ~9000 lbs for some baseline numbers after adding a trans temp gauge
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
2008 Bobcat T190 Compact Track Loader (A55314)
2008 Bobcat T190...
2015 Ford F-350 Knapheide Service Truck (A55852)
2015 Ford F-350...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
