Your towing rigs and trailers
   / Your towing rigs and trailers #2,551
according to builder the trailer is 5000 lbs but I have not gotten a chance to weigh it yet. I have mixed numbers on the truck one place I read 18,000 lbs and another place says 14,800 lbs but it is a 2016 Silverado 2500HD with the Duramax and Allison combination.
   / Your towing rigs and trailers #2,552
I bet there is a degree of pucker factor when loading and unloading equipment on that thing.
   / Your towing rigs and trailers #2,553
as soon as I got it we loaded my grandsons van and carried it to the transmission shop it was the easiest I ever load and unloaded a vehicle that was not drivable. He done the steering as I was running the winch and lowered it as soon as the tires cleared the bed. I have not had a chance to load the tractor yet.
   / Your towing rigs and trailers #2,554
You should have s manual, but you should of also received a duramax manual. Numbers are all posted in there. It should be listed as 5th wheel and bumper pull.
   / Your towing rigs and trailers #2,555
   / Your towing rigs and trailers #2,556
I believe I read 14,200 in the book
   / Your towing rigs and trailers #2,557
That's pretty slick but I would strongly consider a pintle hitch setup and 2.5" hitch shank. As far back as the axles are it looks like it would be quite a bit of weight on the truck.
Brett
the trailer is tongue heavy and I pointed that out the first time I saw it, when I brought it up he said to slide the bed back a little if I had it loaded to heavy in the front so on my way home I felt like it was heavy and I slid the bed back about a foot and it pulled like a different trailer. I am considering sliding the axles forward or shortening the tongue.
   / Your towing rigs and trailers #2,558
So max capacity is 9200lbs. That should cover all three of your listed machines. Sounds like a good photo op to me... :)
   / Your towing rigs and trailers #2,559
Some "European perspective" as some have called it, though some would prefer it to be posted in the "towing or hauling something wrong" thread :p
I needed a pair of wheels for my bale trailer, which i couldnt get anywhere because the machinery wreckers in my area sold a truckload full of their used tires to Poland. So i bought an old single axle Claas selfloading hay wagon, built 1983, of which the owner already used the sideboards for something else.
To get this all on my trailer, we cut the axle bolts loose and cut the frame right behind the intake. Because a 3 ton manure spreader weighs 800kg, i estimated this hay wagon would weigh 1500kg.
It turned out to be a little heavier, because the mans small excavator couldnt lift it on the stick, we had to hook the strap around the main boom.
On the highway on-ramps i would lose speed in 5th gear, but otherwise the 2.5 TDI hung in at 1700rpm and 90kmh pretty neat. We got it home safe, with no instability issues at all. Last week i loaded bricks for my BIL, and after getting home i calculated that i had more than a cubic meter of wet concrete on it, which is 5.5-6k pounds net, and probably 7 to 7.5k gross. My guess is that this load was near the same weight.
This was the 2nd heavy load on this trailer after i rebuilt it, which consisted of lengthening it, and making a new V towbar of 2x4 inch tube, from the first axle all the way to the tow ball, lowering it by 5 inches and putting low profile 195/50R13 tires under it. Because this trailer is quite wide, it has the same trackwidth as trucks, so it never wanders in and out of dipped truck lanes.
I will save all the chains and sprockets as well as the heavy angle gearboxes for future use, as well as the cutting blades to use as weld-on wearparts, and maybe use the floor for my manure spreader, which has a rotten floor and a worn out conveyor chain. Then the rest will move on to the scrap trader, which will get me about 15 ct per kg nowadays.
   / Your towing rigs and trailers #2,560
That is quite a load^^^
Growing up few towed with pickups around here... Station Wagons were the tow vehicle for many... 400, 454 and 455 V8 motors and off camping or to the horse show.
My uncle towed his SCCA race cars with a convertible Buick...
Kawasaki Brute 800 ATV (A55853)
Kawasaki Brute 800...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2015 International TranStar 8600 T/A Day Cab Truck Tractor (A55852)
2015 International...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
