Your towing rigs and trailers
   / Your towing rigs and trailers #181
This is the truck that I have demoted to #2 when I replaced an '89 Dakota with a Super Duty F-250 with PowerJoke diesel, a crew cab short bed 4x4.
This truck, partially hidden in this morning's fog, is a '97 Dodge/Cumins diesel extended cab with Stahl Grand Challenger service body (customized) and Reunel custom front bumper with dual receiver hitches, 12,000 lb Warn winch, twin driving lights, twin fog lamps, light guards (1 1/4 inch solid round bar) and solid stainless steel push bars (keeps the BMW's out of the radiator.) The front bumper with winch weighs 500 lbs and the metal is custom formed 1/4 inch plate. It has 6 custom spring sets. Front coils are formed from elliptical rods for variable rate, rear leaf packs and overloads are all custom. There are 10,000 lb air bags between rear axle and frame so you can adjust the headlights to where they should be when hauling a heavy load. The schrader valves for the air bags are under the fuel flap next to the fuel cap. The bags may be aired independently to accomopdate an uneven load distribution. I bought a twin dial pressure gauge and HD 12 volt air pump but never got around to installing them. IT turns out I don't "play" with the air bag pressures all that much and I do carry a smaller 12 volt compressor which works just dandy.
The wheels are 19.5 inch Alcoa aluminum and the tires are 245R19.5 Michelin steel belted radials in Mud and snow tread with max inflation pressure of 110 PSI. The fuel tank was replaced with 65 gal after market tank. There are 2 each 220 AH 6 volt golf cart batts in custom boxes in the rear wheel wells (in series you get 12 volts for extra storage of solar electricity when the camper which has roof top solar panels is on the truck.)
The automatic tranny (Aftermarked BD HD tranny) is assisted by a Gear Vendors Over/Under drive aux tranny for 8 forward gears (in 2x4 or 4x4 hi range only) The injector pump was swapped out for a much higher pressure unit and the injectors for units with much finer holes. This gives more HP, torque AND slightly higher MPG at the same time by burning fuel more efficiently. There is an EGT pyro to monitor temps so you don't melt anything racing up a grade with a heavy load. On the flat it is hard to overheat the EGT but it is possible up a hill with a heavy load/tow if you keep the pedal to the metal long enough.
There are dual gas charged front shocks (Bilsteins) and there is an exhaust brake to assist, especially on long and or steep down grades. The receiver hitch (rear bumper) is replaced with a Class V assy rated at 14,000 lbs. I have an extension/adaptor that allows towing a trailer behind the truck while carrying an extended camper. This downsizes the class V receiver to a standard 2 inch drawbar and down rates the carrying capacity to 6000 lbs while extending the drawbar a few feet behind the standard ball location.
The rear dock bumper is boxed in for greater torsional strength as the rear camper tie downs are weld-on pad eyes on the bumper. I have replaced the mandated People's Republic of California intake manifold with poor distribution due to an EGR arrangement with a "Free States" intake manifold with much better flow and distribution.
I carry a 4 ft long 600 lb-ft torque wrench for use as a breaker bar for the tire lugs as well as to set the torque on the wheel lugs (450 lb-ft)
There are lots of other minor little mods like the CB, VHF and UHF ham radios, GPS, (rear view camera coming soon), and after market mirrors that extend/retract electrically as well as adjust and have breakaway mounts that ONLY WORK GOING FORWARD (unfortunately) but the above is the bulk of the changes. There are little touches like mud flaps at the front of the front wheel wells which if you have seriously off roaded a Dodge like this you will understand. The muffler was replaced with a larger HD unit just slightly louder but way less restriction in keeping with the performance of the 4 inch exhaust. The turbo spools up much quicker so less response lag. (Still, the F-250 with totally stock engine will smoke the Dodge off the line and through a quarter mile as it has much more acceleration. However, loading the tractor onto the trailer attached to the F-250 and the truck nearly goes airborne and towing a heavy load behind the F-250 DOES NOT FEEL NEARLY AS SECURE.
Pat
   / Your towing rigs and trailers #182
Here is my '97 F-350, my 28' Delta and my '07 TC-55DA.
   / Your towing rigs and trailers #183
Pictures of my '04 RAM Q-Cab, JD2520 TLB, and 16', 7000# Topbrand trailer. I added the wood sides for hauling stuff like tree limbs/brush, bagged mulch, firewood, etc.
Note that even a small frame TLB like mine just barely fits on the 16' trailer. Next rig will probably be a 3/4 ton PU (Cummins maybe:cool: ) and 20', 10,000#. I have visions of adding a skid loader sometime in the future.
   / Your towing rigs and trailers #184
Are those 2,000 lb. bales? :D
   / Your towing rigs and trailers #185
Closer to 1,000 lbs. It's still quite a load at that much.:)
   / Your towing rigs and trailers #186
How did you tie that load down? Using the side tie downs with round bails and a high load has got to be the towing equivalent of herding cats? I'm sure there is a easy solution I can't see.
   / Your towing rigs and trailers #187
I tie the top 5 rows down from the side, the rear bottom 2 get a strap around the backside, and the one on the front gets tied on the side.
I tried strapping them from front to rear, but I lost 4 of the top bales before I got out of the field.
   / Your towing rigs and trailers #188
I tie the heck out of my loads now. I dislike having to load a trailer twice so anytime I have to haul hay I use almost every strap I have. I strap length wise and side ways to prevent any shifting. Then I stop after a couple miles and retighten. The hard part was getting straps long enough to strap length wise in one piece. I didn't have to have them in one piece but it is easier then hooking chains up between the trailer and straps.
I did get lazy once and started using the dump trailer for a short haul of mulching bale and dropped three of them in the road as I came up the hill to go onto the road from the field. After that I tied the heck out of those loads too.:(
   / Your towing rigs and trailers #189
I guess what I'm missing here is if you cinch down the side straps tight enough they will stay put on top of the upper bales? Motorists need to be thankful that I don't transport hay for a living.;)
   / Your towing rigs and trailers #190
I can put a lot of force on the straps. I use ratchet binders like the truckers use on their flatbed trailers. Once I get out of the field, I stop and ratchet them down some more after the bales have settled a bit. I haven't lost one yet *knocks on wood*, and I am driving on some twisty, hilly back roads.
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2012 MACK CHU613 DAYCAB (A55745)
2012 MACK CHU613...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
