Be extremely careful with bearing buddies on axles with brakes. They have a tendency to push grease (or at least the oil that separates from it) past the inside seal. This leads to a destroyed set of brakes and no braking capacity plus an expensive repair. Don't ask me how I now. The service center that repaired my trailer advised me to remove the bearing buddies and just service the axles annually as recommend by Dexter. They told me they see this often on travel trailers. Same thing with the easy lube axles. If you get carried away with the grease on those, it can push the grease out the back side. The bearing buddies have a spring that keeps constant pressure on the grease which in turn forces it past the seal over time.
