Your opinion please?
/ Your opinion please?
The frame work is 3"x3" x3/16" , winch is rated 10,500 & the cable is 3/8" and is rated to break at 12,000. Sure hope that I don't bend or twist anything. I will be extra careful.
/ Your opinion please? #22
Don't the Farmi and other brands mount their winches lower and use pulleys for pulling from above? Looks like if the tractor don't slide it'll rotate over on its back.
yes the Farmi does mount the winch down low cause there would be too great an angle in the PTO shaft.There cable is high and that is the point that it is actually pulling from. And you are right it could roll over on its back thats why you have to be careful working in the woods.
/ Your opinion please? #25
With the winch mounted high like that, there is probably a big difference in safety between reeling in the winch to pull something and driving the tractor forward. Driving the tractor forward can cause it to flip back in a big hurry - faster than you can react. The winch speed is slow enough so that it can be shut down if it starts to pull the front of the tractor off the ground, right?
I also notice the feet on the bottom of the winch frame - they move the pivot point even further back from the rear axle. the winch would have to pull the whole tractor up and over the winch frame, pivoting on those feet, right?
- Rick
/ Your opinion please? #26
Hi
but, what would happen if the relay malfunctioned and the motor wouldn't shut off? It might keep pulling the tractor over, the other way mounted or pulling from a low point it would only pull the tractor back not over. Just a thought what if.
charlie
The feet do help to stablize the whole machine and keep it from being winched rearward. There is no relay to malfunction because it is hyd. front weights are recommended so I just leave the blower on. we have very little snow here now. Nothing that we do with machinery is ever fool proof as far as saftey goes. so just go slow and be extra careful.
/ Your opinion please? #28
Sorry I said anything.
I am not sorry that you said something, because I did ask for anyone's opinion. I always welcome comments, it sometimes points out things that I may have overlooked. Have a happy new year.
/ Your opinion please? #30
Deerlope three things the blade helps with 1 is buttin the logs up in the landing or yard and the other is to prtrac the pto and other parts from getting a log jammed into the pto from under the legs. Another thing is with the blade on the rear you can lower it close to the ground and back single logs up.
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
