Your Opinion Please
/ Your Opinion Please #1
klem531
Nortwest Indiana
Ford New Holland 1620
Hi everyone, I would like your opinion on buying an implement. Heres the situation. I live on a private gravel road that is about 1000' long. The road gets pretty pot-holed up several times a year. In the past, I had an old International 3444 loader back-hoe that I would drag the road with and sort of fill in the pot-holes. Well, I have sold the back-hoe and bought a White Field Boss 37. This is my first experience with a 3 pt. hitch and I was wondering what attachment would be the most usefull and cost effective to get the job done. A blade seems the most obvious but I was wondering if there is some type of box scraper that would cut through the compacted gravel and smooth out these dang pot-holes. Thanks, Tony K.:D
/ Your Opinion Please #2
Box blade would work, rear blade would be helpful if your in a snowy region.
Tell us more about where you live.
/ Your Opinion Please #3
klem531 A.K.A. Tony K:
Welcome to TBN :D! You are probably going to receive a lot of posts from other members who will advocate for the 3PH attachment they have. IMHO a heavy back blade with tilt, a heavy duty boxblade/scraper, or a product if my memory serves me correctly :confused: by TractorByNet.com | John Deere, Kubota, New Holland, and more! would work. Jay
/ Your Opinion Please #4
Tony K:
I checked that site and it was not the attachment I thought it was. I did find it though. It is a product of ATI Corporation their website is ATI Corporation - Home. Those units look very expensive. Jay
/ Your Opinion Please #5
There is a grader attachment that has 2 blades in it at angles that is designed for smoothing out roads. Those work good (according to posts - never used one myself so take that into account). Box blade - scarifiers to loosen the hard dirt and the box to move gravel from high to low spots.
Back blades also work, but they will often skitter across the surface as they are typically pretty light .
On implements like this you want to spend your money wisely. Look to the total weight of the attachment before the width. You want to be as wide as your rear tires and as heavy as you can afford.
Lots of historical posts on these implements here. Even one on box blades showing pictures of the various models.
jb
/ Your Opinion Please #6
Before you spend a lot of bucks try a simple york rake. I;ve used one for the last few years and it works great.
Thanks so much for the responses. I live in Northwest Indiana right on the edge of the snow belt. As of right now, I do not plan on using my tractor for snow removal as I have a snowplow on my pickup. But that is always subject to change. I like the Idea of a bok scraper. I would like to be able to have one implement that would loosen the gravel/ dirt and deposit it smoothly behind the tractor.:rolleyes:
I'm not sure what a york rake is but I will look in to it thanks.
/ Your Opinion Please #9
I have used both a rear blade and a box scraper. The box scraper works much better because as you stated it loosens material to fill in the holes. Rear blades can be difficult to control for depth of cut/backfilling especially without hydraulic tilt and angling. Box blades with the scarifiers removed also do a good job on snow if its not too deep. Gerry
/ Your Opinion Please #10
I've never even used one of the regular back blades, but I sure used my box blades a lot. Before I bought my first box blade, I thought I wanted a back blade because of the angling ability. But a neighbor had one, said he never used it after he got a box blade, but that I could take it and use it anytime I wanted. After getting the box blade, I never did try out the other kind.:D
/ Your Opinion Please #11
So Jay, which one should I recommend? The ones that work, or the one that works the best?:D ;)
/ Your Opinion Please #12
I don't care for box blades or rear blades. The problem is they tend to make a rough road even worse. If your tractor hits a dip, then the blades goes up in the air. If the tractor hits a high spot, then the blade goes down and cuts a low spot. It doesn't take very long to create a roller coaster ride.
Roadrunner makes an attachement that you drag along the road. It has two blades. They both cut at an angle and spread the rock behind it. From what I've heard, it's the only attachement that actually works.
There are quite a few brands and names for it, but this is the one I know of.
Roadrunner Construction Equipment - Out Performs Complex Motor Graders on Many Applications.
Eddie
Eddie
Thanks for the link, now thats what i'm talkin about. I am going to request the video right away.
/ Your Opinion Please #15
Brian A.K.A. MtnViewRanch:
You are a stitch :D. I uh :confused: choose door #4. I really like that grader thingy as well as your layout of "toys" :). I have to keep mine spread out so as to not agitate "She Who Must Be Obeyed" :mad: and "Who Always Remembers" :( . Luckily for me most of my attachments are covered by ice and snow except for my box blade/scraper which is very, very convenient for breaking up my ice field of a driveway this Winter(?). :cool:. My wife likes that attachment :). Nice attachments BTW. I would have responded sooner, but dialup is a pain. Jay
/ Your Opinion Please #16
/ Your Opinion Please #17
Eddie
i would recommend one of theses to solve the diping problem. Works like a box blade but you can turn loaded and no dipping problem that is infamos with a 3pt Hitch
http://www.cammond.com/PDF/COMPACT DRAG.pdf/
/ Your Opinion Please #18
The Landscraper eliminates a lot of the negatives I've just read about in your posts. The heavyduty weight box lets you control the weight of the implement, hydraulic tilt (up to 12") lets you crown the road nicely for drainage, tongue goes through and connects to the back of the box/blade for strength, and transport lock lets you tow it longer distances to other locations behind your truck. I have never talked to any customer that didn't like the performace of this product, in fact, they complain more about their neighbors asking to borrow it. Front-End Loaders by Westendorf: loader for tractor, shade canopy, wagons, manure & landscaping equipment.
/ Your Opinion Please #19
Now I am not 100% sure, but the better the implement works on the road, the more $$$$$ that it costs. You just need to decide on which will work the best for you for your money.
/ Your Opinion Please #20
Do you still have "Rabbit Ears" as an antenna on your B&W TV and a typewriter as well?
