Your last generator Maintenance Run
   / Your last generator Maintenance Run #6,241
A reliable grid is the cornerstone/foundation of modern life... your #'s are great.
Once you get into a Cali type scenario..... Island mode starts looking pretty good. UR had plenty of surgeons who previously had been bragging about their PV systems and Teslas, crying pretty hard during extended "safety" outages....
The advantage I see with a designing your own battery system is you can make it much more accessible for service, than many vehicle installations are. That said, most people want everything MTCE-free today, and don't want to deal with batteries.
Rgds, D.
Brand new Lightning in Doc parking lot this morning...
At least half new physician autos have some component electric.
The EV home tie in is coming...
   / Your last generator Maintenance Run #6,242
Brian Johnson ended up with hearing problems, not from fronting a loud rock band, but from racing cars.... we all likely need to use better hearing protection !
(not sure where the perma-bold ^ came from....)
Thnx for the feedback on the alarm. ".... in basement" ? < Did you change your setup to run indoors ?
Rgds, D.
the power has returned alarm is installed in/just outside the main panel box in basement.
Once I'm on gen power, I turn on the alarm. When street power comes on and activates the alarm,
I then turn it off. Same as before, gen sitting outside.
I used to have an old Radio Shack audio meter. I'd love to measure the output.
Plus the noise pulses, truly irritating, very effective
meaning likely you would hear it on second floor if it goes off in basement.
Great 411 on the alarm d !
You've probably seen them already.... some good Ytube videos around on acoustic panels you can build to absorb/re-direct sound a bit, on portable gens.
Rgds, D.
   / Your last generator Maintenance Run #6,244
ive installed those alarms for many of my portable gen customers over the years. ones that dont have street lights or close by neighbors to alert them of power restoration.
any of you have the big portable Generac?
I wonder if there was any cover at all over gen if sun would overpressurize tank...???
Thanks for posting that d. I don't have anything that big, though I do find myself drawn to their one I've posted up here a time or 2..... good price point for something in the near 10kw range, and FI.
Sounds like a design or manuf error with the roll-over valve...... not the first time I've seen an Added Safety device causing a problem - this time, in the exact area it is supposed to address.
An example of why Designs Have To Iterate.....
Rgds, D.
   / Your last generator Maintenance Run #6,247
Did my three month run today. The gennie only has about 20 hours on it. Ran it under load for about 20 minutes today, running my 3000 psi pressure washer.
Battery was good. Started right up!
   / Your last generator Maintenance Run #6,248
This reminds me that I have to get a price on a transfer switch and cord for the house. We have a EU6500 on a vending trailer I can use if I needed it.
   / Your last generator Maintenance Run #6,250
Looked at the website and all it did was cornfuse me....
I already have all of that and have for years. Vacuum breakers for the main input/output and it's all automatic switch over.
Just about to start taking the diesel standby apart and install it in int's new fully enclosed aluminum home, courtesy of Gererac and 2700 smackers. Thinking I'll pull all the switchgear first and then take one if the tactors with forks and a couple lifting slings and pull all the mechanicals (engine, generator) together in one shot and set them in the new enclosure.
Already pulled the mains so it's just sitting and waiting for the wrench.
Don't have to worry about the usual underside diesel storage tank because when I bought it I specified no tank. It's direct plumbed into my 500 gallon bulk diesel tank.
Will be nice to get shut of the rusting steel enclosure it came with
Be my luck we loose power during this exchange too.
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2017 Ford Explorer AWD SUV (A56859)
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
