Your last generator Maintenance Run
   / Your last generator Maintenance Run #4,641
It is a single cylinder B&S
90cummins
   / Your last generator Maintenance Run #4,642
Thanks Dave it looks like that manual covers my engine.
I will verify the info tomorrow.
90cummins
   / Your last generator Maintenance Run #4,643
Up early to get going on the engine rebuild.
I looked thru the files and found everything I need except for the valve seat angles & margin width.
Manual includes instructions on valve grinding/lapping and guide replacement and reaming but no mention on the seat details.
Not a problem as I have the cutters to match the seats.
Just odd they completely omitted those details.
Thanks Dave for the info!
90cummins
90cummins
Glad that worked out 90 :thumbsup:
Did a few tours of duty (day job) as a component engineer..... so I can pretty much search in my sleep :laughing: thot I'd give that a quick shot.
Rgds, D.
Yup, i truly hate gfcis. I installed a $53 siemens GFCI on a lake pump for a customer. New pump and wiring. Lasted 1 week. Kept tripping....even if all wires were disconnected. Had to replace breaker.
Did i say i hats gfci痴
This chat had me thinking about arc-fault interrupters.....Haven't checked code, but I suspect they are intended for indoor use.
What is the collective verdict on arc-fault-interrupter reliability/longevity ?
Rgds, D.
   / Your last generator Maintenance Run #4,646
Top of my list of things to do is rip out absolute garbage Siemens ARC fault breakers from Barn. Tired of going in there with a flashlight in leau of the proper lighting!
The utter garbage that is rammed down our throats by GOVERNMENT!
0 for 2 with Siemens...... wonder if other manuf are as bad ?
Rgds, D.
   / Your last generator Maintenance Run #4,648
here we only need garbage ark faults for bedrooms. Barns and shops need garbage gfci units
   / Your last generator Maintenance Run #4,650
All this government protection from our self......makes me wonder how many people actually got killed weather plugging in a toaster or skillsaw back 10, & 20, &30 years ago. Is the tail (manufacturers) wagging the dog (electrical code writers) ? They were just introducing arc fault breakers when we built. Fortunately our inspector was not a fan either.
SHOP SNAP ON TOOLBOX (A55745)
SHOP SNAP ON...
2018 HINO 195 16FT BOX TRUCK (A56129)
2018 HINO 195 16FT...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
Case 1020 25ft Draper Head (A55302)
Case 1020 25ft...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
CATERPILLAR 928F LOADER (A52707)
CATERPILLAR 928F...
