   / Your last generator Maintenance Run #4,641
It is a single cylinder B&S
90cummins
   / Your last generator Maintenance Run #4,642
Thanks Dave it looks like that manual covers my engine.
I will verify the info tomorrow.
90cummins
   / Your last generator Maintenance Run #4,643
Up early to get going on the engine rebuild.
I looked thru the files and found everything I need except for the valve seat angles & margin width.
Manual includes instructions on valve grinding/lapping and guide replacement and reaming but no mention on the seat details.
Not a problem as I have the cutters to match the seats.
Just odd they completely omitted those details.
Thanks Dave for the info!
90cummins
90cummins
Glad that worked out 90 :thumbsup:
Did a few tours of duty (day job) as a component engineer..... so I can pretty much search in my sleep :laughing: thot I'd give that a quick shot.
Rgds, D.
Yup, i truly hate gfcis. I installed a $53 siemens GFCI on a lake pump for a customer. New pump and wiring. Lasted 1 week. Kept tripping....even if all wires were disconnected. Had to replace breaker.
Did i say i hats gfci痴
This chat had me thinking about arc-fault interrupters.....Haven't checked code, but I suspect they are intended for indoor use.
What is the collective verdict on arc-fault-interrupter reliability/longevity ?
Rgds, D.
   / Your last generator Maintenance Run #4,646
Top of my list of things to do is rip out absolute garbage Siemens ARC fault breakers from Barn. Tired of going in there with a flashlight in leau of the proper lighting!
The utter garbage that is rammed down our throats by GOVERNMENT!
0 for 2 with Siemens...... wonder if other manuf are as bad ?
Rgds, D.
   / Your last generator Maintenance Run #4,648
here we only need garbage ark faults for bedrooms. Barns and shops need garbage gfci units
   / Your last generator Maintenance Run #4,650
All this government protection from our self......makes me wonder how many people actually got killed weather plugging in a toaster or skillsaw back 10, & 20, &30 years ago. Is the tail (manufacturers) wagging the dog (electrical code writers) ? They were just introducing arc fault breakers when we built. Fortunately our inspector was not a fan either.
2006 FORD F-250(INOPERABLE) (A55745)
2006 FORD...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2020 Freightliner M2 106 Elgin Street Sweeper Truck (A55852)
2020 Freightliner...
New/Unused 78in Quick Attach Skid Steer Grapples (A54865)
New/Unused 78in...
GMC 2500HD 4wd Service Truck (A55315)
GMC 2500HD 4wd...
22 TON PNEUMATIC JACK (A55745)
22 TON PNEUMATIC...
