Your last generator Maintenance Run
   / Your last generator Maintenance Run #3,841
Ran the champion for 10-15 minutes today while I was getting ready to snowblow the driveway. So good to know it starts even at -16 celsius
   / Your last generator Maintenance Run #3,842
Kevin, good news on the Champion. My little one starts ok in cold but not if it's been sitting too long. It likes being started frequently, think getting initial gas through carb is the challenge.
   / Your last generator Maintenance Run #3,843
My champion will only run with partial choke now... another casualty of California fuel
   / Your last generator Maintenance Run #3,844
I had a generator that was like this and a friend of mine adjusted the jets and then it ran as it was supposed to. I'm not an engine mechanic so I don't know exactly which jets he adjusted.
   / Your last generator Maintenance Run #3,845
Dollars to Donuts the fuel flow in carb is partially obstructed... I'm guessing corrosion
Train in Peace Guys ..... :thumbsup:
I know you work on cars older than I am ur (therefore, Old ! :)), but with how low-cost complete carbs often are today, I'd grab a new one for a fast fix, then rebuild the original some rainy-day....
Rgds, D.
   / Your last generator Maintenance Run #3,848
   / Your last generator Maintenance Run #3,849
and a handy dandy how to guide online
not hard to do, just a lot of steps
Champion Help Center - 31-35 watt Inverter Carburetor Replacement - YouTube
which begs the question using E0 premium gas, why should my carb be gunked up after only four years using additives?
maybe the holes/jets are awfully small and can't tolerate anything in there.
that is weird. Ive been using nothing but ethanol free fuel in all my stuff for many years, and I do not use any additives. I have never had any further issues since losing the e10 junk fuel.
   / Your last generator Maintenance Run #3,850
Water in the fuel through contamination or condensation?
2015 CATERPILLAR D7E LGP CRAWLER DOZER (A52707)
2015 CATERPILLAR...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A57024)
2016 KBH...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A56138)
2014 INTERNATIONAL...
L-SHAPED FUEL TANK (A55745)
L-SHAPED FUEL TANK...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
