Your last generator Maintenance Run
   / Your last generator Maintenance Run
Well got it fixed again, it was a fuel issue the injector this time. I finely found some STP injector cleaner and I hope that will help in the future. As for loads I'm running 2.5 hp AC unit and a 1.5 hp. AC unit along with a 2 hp. well pump. Not all come on at the same time so it's doing ok, not tripped breaker yet...??? As for fuel it will run about 14 hr. on 2 gal...
Can be hit/miss with some of those, hopefully yours behaves..... let us know, as time rolls on.....
Rgds, D.
   / Your last generator Maintenance Run #2,633
This OnanQD project is getting more involved than I had planned. I was going to put the battery, fuel tank, 120 to 120/240 transformer underneith and find out it ejects rather warm air out the bottom, normally onto the road. It also had a lifting ring inside a cover on top. I loose that feature on account of all the weight I am adding.
It all requires more thought and engineering than I had intended to devote to this. The major part, the transformer I got on a 600KM road trip and a hundred phone calls. I never even thought that (used) 120/240 to 120/240 7.5 -10 KW transformers were so scarce.
I just came accross this Military Version of what I have. I don't have the air cleaner sticking up out of mine. Now I wonder, where mine is?
Onan Cummins 75 Quiet DIESEL Generator - YouTube
   / Your last generator Maintenance Run #2,634
Probably a bus (ie: greyhound type bus).
Aaron Z
New Military surplus off eBay.
Niehoff supplies extremely HD efficient 6 phase alternators to many OEM’s.
This particular model N1603-2 will deliver 28 volts & 180 amps at 1700 rpm.
Brushless design.
90cummins
Can't remember if it was in your pics - different air cleaner on yours, or it's missing altogether ?
Those "one or 2 afternoons" type of projects can grow dramatically....... :blacksmith:
Rgds, D.
Niehoff supplies extremely HD efficient 6 phase alternators to many OEM痴.
Brushless design.
90cummins
Thanks for posting the model #....... nice design (export controlled, should be good.....) and capacity. External regulator :thumbsup:.
What did you choose for a pulley arrangement ?
Rgds, D.
??? 28 volts?
Generally, as power levels go up, you want to move to higher voltage (IR loss, same reason utilities use high-voltage transmission lines.....).
Above light-vehicles, there are many 24volt DC vehicle systems, which need 28 volts nominal to charge. Two 12 volt batteries in series is a common configuration.
For Off-grid applications, 24volt and even 48 volt systems are common.
Energy Efficient Refrigerators - SunFrost.com
Rgds, D.
   / Your last generator Maintenance Run #2,639
Well last gen test run was thanksgiving. Needed power in the field today. Only gen I own is the 7k gasser that we use for backup power. It fired right up and ran the power washer no problem. Ran for about 3 hrs total.
Nice to get its test run in and some work done at the same time.
Hopefully that means no power outages for me.
SKID MOUNTED CONTAINMENT (A55745)
SKID MOUNTED...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
1999 VaXcavator VT500D Towable Vacuum Trailer (A55851)
1999 VaXcavator...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
