Your last generator Maintenance Run
   / Your last generator Maintenance Run #2,641
Generally, as power levels go up, you want to move to higher voltage (IR loss, same reason utilities use high-voltage transmission lines.....).
Above light-vehicles, there are many 24volt DC vehicle systems, which need 28 volts nominal to charge. Two 12 volt batteries in series is a common configuration.
For Off-grid applications, 24volt and even 48 volt systems are common.
Energy Efficient Refrigerators - SunFrost.com
Rgds, D.
Amps * Volts = watts
So if you up volts you can get by with fewer amps to maintain the same power (watts). As you have to size wire based on amps rather than volts you can use cheaper, lighter & more flexible wire, connectors & other components. You end up with less power loss & a more efficient system.
Some have tried, but there's no point arguing with the Law of Ohm :cop::judge:.
Rgds, D.
Nice to get its test run in and some work done at the same time.
My Scottish DNA seems to help the performance of my Gen-Run Memory, when I do both. :D
Rgds, D.
   / Your last generator Maintenance Run #2,645
of batteries and Bertrams:
speaking of volts, there is quite the "war" going on in cordless hand tools as to voltage, now up over 100VDC.
Would not want to put some of these things down in a puddle of water...
My old Bertram was 24 volts, whole lot of 8 volt batteries. All you had was the built in oem ferro resonant charger to handle them.
Water add intervals were not long and a lot of work. Down on my stomach in my engine room, batteries were on centerline all the way down. 153 pounds a piece and I could never do it myself. Changed them out twice over 13 years. Always lusted after those red Rolls batteries/Surette, but I was on a far different budget.
15kw 1981 Onan 4 cyl, dirty little beast, about 2500 hours, but keep clean filters on it, which always left one soaked in diesel, and your wife going pew when you headed out, and if the starter solenoid you replaced remained reliable, which you never knew, it would start with a clank of smoke and mechanical unhappiness, rattle away and commence to slightly vibrate the entire 25 ton boat. Now there's a generator that needed a balance shaft or something. 40wt straight grade Delo on the Detroits and probably 30wt or 10/30 in the Onan gen.
And the question of course, as it always is for all of us, will it start? I had a remote start in the boat's salon and would stand by the window where I could see the gen exhaust. First to make sure the water was spitting out, seriously important for a marine gen, and then how long it took for the smoke to clear. Even after all those years, always less than a minute. Perfectly normal for a non emission diesel.
The grief on those engines was, as usual, what hung on the outside, the pumps, the filters, belts, things that break or clog when you are far offshore, out of the sight of any land, and you'd better know how to do it. And have spares for your spares. With an old boat that had crud in the tanks and condensation issues constantly, in this case South Florida, my generator maintenance runs were pretty constant. Usually once I shut down and plugged into shore power, and things cooled, I'd be changing oil or a filter, and always restart it to test for leaks. Nothing like timing it to send some soot on a passing sailboater walking down the dock. :D
I have never worn gloves while working on machinery. Many folks can and I envy them. My hands would get sweaty or I'd drop too many things or getting little screws in took only the lightest of touches.
I'm sure a few of you have taken off a pair of gloves at some point and went on without. But around batteries I am super careful. Don't want that stuff in my eye and I have enough older batteries where cleaning up corrosion is a way of life. Plus it's damp here where I live, so I use a lot of waxy sprays and battery sprays after neutralizing the acid. Usually means a good wash for the whole battery area to dilute any acidic corrosion that's been washed off and landed who knows where. And then out comes the blower, always the blower. Have two different sized Makita cordless blowers using same battery pack. Had them a long time, at first for just this, blowing grass out of the engine compartment of my rear engined Gravely garden tractor. I don't know how many times those Makitas fall off my golf cart and they just keep on going. Really should get a better hold down arrangement...:rolleyes:
I'm sure there are other boat gen maintenance stories to be told here...
That 15kw # threw me off for a bit...... many folks up here get out on the water to enjoy the heat, but once I thought about it, realized you'd want that much AC on southern US yacht....
Shouldn't even joke (I can relate to confined-space work, and understand the criticality of the maintenance you describe..... I was told of one good sized modern wreck in the Great Lakes over nothing more than no replacement fan-belt onboard.....), but your description of below decks work flashed up a modern-day Ben Hur Galley Scene image for me this morning....... Are We Having Fun Yet ?
Nice being on the water, but boats need a lot of constant attention...... Or Else........
I've had good luck with Makita, but so far all of mine are corded. Did buy one years ago, but that was company money..... almost middle of nowhere, needed a small cordless drill to finish commissioning some custom electronic installations, so found a hardware store and bought the lowest cost Makita drill I could find, that had a replaceable battery - need something compact, for that application it worked great.
Haven't looked at the DC high voltage stuff yet.........
Buy a Drill, Doubles as Taser ? :laughing:
Rgds, D.
   / Your last generator Maintenance Run #2,647
Thunderstorm rolled through just before 5PM & lost power shortly after following some blips. UPS units on the various machines were beeping til the backup kicked in. Power company says they expect things to be fixed a little after 10PM tonight ...
Wife is very happy with our setup. I'm happy I didn't have to go out in the rain to set something up.
Happy Wife, and you don't have to go out in lousy weather !
Double value for the money :cool2:.
Rgds, D.
   / Your last generator Maintenance Run #2,649
After almost fifty years I finally mapped out the fuse panel in the house for exactly what is on what circuit. I was installing some new lighting a week ago and decided, I am going to install some strategic LED lighting in the house on a small UPS. They will continue to operate if on already and will have lighted Decora switches to find them in the dark (as usual).
I wonder if the neutral is isolated or not on a small APC UPS.
   / Your last generator Maintenance Run #2,650
Yep, UPS units can be useful for lots of things other than just a desktop & peripherals. There are enough power "blips" around here that I added UPS support for anything I don't want to wait for on a reset and/or generator start. Cordless phone base/answering machine, house network components, security camera NVR, wireless printer, 3D printer, satellite receiver & TV, etc. (as well as PC's & external drives, of course). Most had been set up before we got the auto transfer system & were sized to provide 20-30 minutes support to give me time to set up a portable unit in case of outage.
BTW, newest restore time estimate is now 2:00 AM
ETA Actual restore time was 5:40AM, so a bit over 12 hours
New/Unused 20,000lb Electric Winch (A54865)
New/Unused...
New/Unused Self Dumping Hopper (A54865)
New/Unused Self...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2004 Ranger 195 VX Comanchee Bass Boat with Trailer (A54865)
2004 Ranger 195 VX...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
