   / Your last generator Maintenance Run
Well got it fixed again, it was a fuel issue the injector this time. I finely found some STP injector cleaner and I hope that will help in the future. As for loads I'm running 2.5 hp AC unit and a 1.5 hp. AC unit along with a 2 hp. well pump. Not all come on at the same time so it's doing ok, not tripped breaker yet...??? As for fuel it will run about 14 hr. on 2 gal...
Can be hit/miss with some of those, hopefully yours behaves..... let us know, as time rolls on.....
Rgds, D.
   / Your last generator Maintenance Run #2,633
This OnanQD project is getting more involved than I had planned. I was going to put the battery, fuel tank, 120 to 120/240 transformer underneith and find out it ejects rather warm air out the bottom, normally onto the road. It also had a lifting ring inside a cover on top. I loose that feature on account of all the weight I am adding.
It all requires more thought and engineering than I had intended to devote to this. The major part, the transformer I got on a 600KM road trip and a hundred phone calls. I never even thought that (used) 120/240 to 120/240 7.5 -10 KW transformers were so scarce.
I just came accross this Military Version of what I have. I don't have the air cleaner sticking up out of mine. Now I wonder, where mine is?
Onan Cummins 75 Quiet DIESEL Generator - YouTube
   / Your last generator Maintenance Run #2,634
Probably a bus (ie: greyhound type bus).
Aaron Z
New Military surplus off eBay.
Niehoff supplies extremely HD efficient 6 phase alternators to many OEM’s.
This particular model N1603-2 will deliver 28 volts & 180 amps at 1700 rpm.
Brushless design.
90cummins
Can't remember if it was in your pics - different air cleaner on yours, or it's missing altogether ?
Those "one or 2 afternoons" type of projects can grow dramatically....... :blacksmith:
Rgds, D.
Niehoff supplies extremely HD efficient 6 phase alternators to many OEM痴.
Brushless design.
90cummins
Thanks for posting the model #....... nice design (export controlled, should be good.....) and capacity. External regulator :thumbsup:.
What did you choose for a pulley arrangement ?
Rgds, D.
??? 28 volts?
Generally, as power levels go up, you want to move to higher voltage (IR loss, same reason utilities use high-voltage transmission lines.....).
Above light-vehicles, there are many 24volt DC vehicle systems, which need 28 volts nominal to charge. Two 12 volt batteries in series is a common configuration.
For Off-grid applications, 24volt and even 48 volt systems are common.
Energy Efficient Refrigerators - SunFrost.com
Rgds, D.
   / Your last generator Maintenance Run #2,639
Well last gen test run was thanksgiving. Needed power in the field today. Only gen I own is the 7k gasser that we use for backup power. It fired right up and ran the power washer no problem. Ran for about 3 hrs total.
Nice to get its test run in and some work done at the same time.
Hopefully that means no power outages for me.
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
